Eagleview
Veteran Member
And the flow rate adjustment of the 3-point hitch is hiding somewhere that we can't seem to find.
If it's the same as the TL , the adjuster knob is outside , behind the rear window on the right side . Just in front of the external 3pl lift handle , it has a cable (like a speedo cable) comming off the knob .
Regarding the air con , just make sure the bonnet gas struts are not rubbing on the pump hoses . Mine was , so i wrapped them in Kevlar bandage .
Put a piece of household flyscreen over the radiator and the battery , the grill screens let fine grass cuttings through which blocks the condensor . It is an easy matter to give the flyscreen a quick brush with the engine off to remove it .
Keep an eye on your fuel level when it's getting low as driving along a slope with the r/h side of the tractor downslope will allow fuel to transfer to the right tank , and as the engine draws from the left tank you can run out .
