Rotary Cutter New to rotary cutters, have questions, help please
   / New to rotary cutters, have questions, help please #61
StrangeRanger said:
I guess your idea and my idea of close are different. 5" is not close (that's what she said! Doh!)
Kidding aside, I guess it's just my L3400 then. There's simply no way to make it fit unless I flip the lift arms over. But then my turnbuckles wouldn't reach the lift arms. Oh well...
j
Dito what Farm said... IE.. I can bunji my lift arms together , nearly touching.. my cat 2 tractors .. one can ( has flex-link ends ).. the larger 7610s with non-deluxe link ends one can get to about 8"
soundguy
   / New to rotary cutters, have questions, help please #62
Yep, I think on my Kubota L4400 (similar to a 3400) they won't touch but they'll come within a about a foot of each other.
   / New to rotary cutters, have questions, help please #63
I had a few minutes to kill this morning and was standing in the shop waiting on my son to show up. I threw a tape measure on a couple tractors. My 150 Massey is a CAT I hitch. Outer swing of the draft arms depends on height of the hitch. Approx. mid way through it's up/down travel, it will open to 35-1/2" and close to 4-1/4" at the ball ends. The 2440 Deere is a CAT II hitch with sway blocks instead of stabilizer bars. They can be turned inward to allow CAT I implements or turned out to stabilize a CAT II implement. At their widest point, the ends can get to 39-3/4" apart. With sway blocks set at CAT I position, the ball ends will close to a measurement of 25-5/8" apart.
Both tractors are more than capable of anything commonly needed from the hitch. Neither have any liabilities in their design. They're just totally different in their approach to the same job.
   / New to rotary cutters, have questions, help please #64
If you used a stab chain setup on the cat 2 machine.. would it go any closer.. like for an 18" cat0 sized, cat 1 pined drawbar?
soundguy
A picture might help. I also thot of flipping the arms, but then they'd swing back and forth as the turn buckles won't reach.
j
   / New to rotary cutters, have questions, help please #66
Soundguy said:
If you used a stab chain setup on the cat 2 machine.. would it go any closer.. like for an 18$ cat0 sized, cat 1 pined drawbar?
soundguy
NOPE. Rear end housing is wide enough to prohibit draft arms from going much narrower than where the sway blocks already stop them. Why on GODS green earth would anyone want to put a CAT 0 width drawbar on a CAT II machine anyway? A 60 hp/7500lb tractor would pretzel a CAT 0 drawbar.
   / New to rotary cutters, have questions, help please #67
Ahh. I see it's a design issue.. IE. the designers made the mounting ears so close that the draft arms don't have a large range of motion.. I've seen similar setups that have the draft arms with large balls with ears that allow the arms to have much more range of motion.
If your turn buckles don't reach.. that's when you scab on a nother bit of chain if needbe.
soundguy
   / New to rotary cutters, have questions, help please #68
soundguy
Take a look at a CAT II Deere produced from the first 3-point hitch models in the 50's through the XX55 series of the early 90's. There are NO turnbuckles. Some have a limiter chain that keeps the draft arms from swinging out too far and hitting the tires, some don't. Then there's sway blocks on the inside of each draft arm to limit movement of the arm towards the centerline of the tractor. Simple, effective, little need for adjusting, and not designed to facilitate the use of grossly undersized drawbars on the 3-point hitch.
   / New to rotary cutters, have questions, help please #69
Plain and simple...A design that has the most range of motion seems like it would be the most desireable. That's my entire point. I applaud designers who incorporated this into their machines. Looking at his pic... moving those ears another 3/4" apart, and adding a lip and large(er) ball for the end of the draft arms.. he would have gained much more range of motion.
"Grossly undersized" is a completely arbitrary term. If person A has a cat 2 tractor that can hitch to a cat 0 implement, and person A has said cat 0 implement and can use it, and does,.. more power to him. If person B has a cat 2 tractor that is unable, by design, to hitch to that cat 0 implement.. and then person B calls the implement 'grossly undersized'.. then I'd have to call that a case of sour grapes, as per the fable. :rolleyes: Nothing more.. nothing less.
soundguy
Farmwithjunk said:
Take a look at a CAT II Deere produced from the first 3-point hitch models in the 50's through the XX55 series of the early 90's. There are NO turnbuckles. They have a limiter chain that keeps the draft arms from swinging out too far and hitting the tires and sway blocks on the inside of each draft arm to limit movement of the arm towards the centerline of the tractor. Simple, effective, little need for adjusting, and not designed to facilitate the use of grossly undersized drawbars on the 3-point hitch.
   / New to rotary cutters, have questions, help please #70
soundguy
You may well see Grossly undersized as an arbitrary term, but using a drawbar intended for a 20 hp or smaller tractor on a 50 hp or larger tractor is, well, grossly undersized.
"Sour grapes" as per fable? That's laughable... And why would I even want to hook a toy-like CAT 0 implement to a 60 hp tractor. SOME of us have more sense than that.
I'm sure John Deere's design engineers are quaking in their boots now that you've declared their hitch system undesirable. Why, I bet they recall and scrap the millions of tractors they,ve built just because you don't "applaud" them.
Probably the most successful and popular modern "big tractor" ever produced is the John Deere 4020. The 3-point hitch on all 4020's has the same sway block stabilization I described. So, maybe a few hundred thousand farmers don't know squat and should look to you for enlightenment?
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A56138)
2020 INTERNATIONAL...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55315)
2015 Freightliner...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
