New Tractor, 75HP Range
/ New Tractor, 75HP Range #1
lead_dog
Hi all,
I've been reading here a bit, but this is my first post. Bought a farm this year (72 acres; 45 pasture, remainder hardwoods) and now it's time for the tractor. I'd sure appreciate some opinions.
I will use it for:
  • clearing portions of woods
  • bush hogging
  • loading soil/backfill
  • loading and hauling stones from pasture
  • grading/maintaining 3,000' driveway
I believe I need an approximately 75HP tractor, 4WD and obviously with a loader. I won't be cutting any hay. Last weekend, I borrowed a JD 5205 (56HP), which was very nice. They have a similar model that is 81HP, and I just believe I should go up, as it's better to have more HP than less.
I'm open to Kubota, Deere, Mahindra, Ford/NH, etc. What are the comparable ones in the range I'm looking for? Any strong feelings on one over the other, or should I just price shop my area (east Georgia)? Lots of Deere, Kubota and NH around there.
Thanks for your help!
/ New Tractor, 75HP Range #2
I just bought a NH TN75DA and I like it a lot
power, comfort, small enough to move, big enough to ride good.
/ New Tractor, 75HP Range #3
I have a JD 5425 and it is rated at 81 engine hp. It would do what you want just fine. I had to change tires on mine to shed a little weight though. My tires were loaded and I weighed just over 12k field ready if I left my FEL and bucket on with my 7' bush hog. With R1's I was just making too many ruts. I picked up a 2nd set of wheels and tires in R4's that aren't loaded. Now I feel as if I have the best of both with the tractor. I can be pretty much a beast all weighted down or I can come in at just 5 tons and be nice and light with my R4's. ;)
/ New Tractor, 75HP Range #4
You do have a big chunk of land, the more you plan on maintaining it, the more tractor you will need.
It sounds like you've done your homework. It was a great opportunity to get to use the 5205. I think they use the same front end drive system as our tractor. Please shop your dealers they will make or break your experience.
We have a 2002 JD 5420, MFWD, FEL, open station isolated platform. It is a workhorse. No major problems except for a new fuel line and battery after almost 5 years. It has a power reverser tranny which is really handy for FEL work. If you have any muddy areas, ponds or slopes I recommend MFWD.
BTW, it shares duties with the little 4310 which I basically use as a weedeater around and under the trees...:)
Good luck on your search, If it were me, I'd look for a clean 2-5 year old machine to try and save some money. I wish I had a cab. If you want a new one, take a serious look at the 5603.
/ New Tractor, 75HP Range #5
Check out the Mahindra 7520...
/ New Tractor, 75HP Range #6
  • bush hogging
Congrats on getting the farm.
I think you may not need quite as big a tractor as you're looking at. It depends on more details of your tasks - how often will you be mowing and will it be all 45 acres? How many stones are you hauling from pastures? How much soil do you need to move?
I have a JD 5105 for similar tasks on 20 acres and it is definitely as big as I need. Sure, even bigger would be a bit faster for some tasks, but it would also be very clumsy for other tasks (like in the woods). I have only a 6' mower and I think the 5105 would power an 8' easily, maybe even a 10' cutter. That would make reasonably short work of mowing even 45 acres if it's only 4-6 times a year.
If you'll be mowing a lot or doing anything else when it's hot and sunny, a cab would be REALLY nice if your budget permits. In fact I think you would be better off with a smaller cab tractor than a 80hp ROPS tractor. Only disadvantages of the cab are cost and bumping into tree limbs - which is being extensively discussed on another active thread right now.
The JD stuff is very nice; I'm happy with it. I don't think you would go wrong with a NH TN, a Kubota Mxx40 series or maybe a Kioti DK55/65. The CASE IH JX series would also be worth a look, though they are quite big and heavy for their hp ratings. All of these are available in cab and ROPS models.
The two things I miss on my 5105, other than a cab, are a hydroshuttle type transmission (called power-reverser by Deere and electrohydraulic shuttle shift by NH; completely different from hydrostatic, FYI) and more gears than the 8 I have. If budget permits, something like a JD 5325 setup with the 12x12 would be really nice. The TN can be setup pretty much identically. The Kubota M series doesn't give you 12 gears until you step up to the M8540 which, IMHO, is bigger than what you really need.
/ New Tractor, 75HP Range #7
I've been very pleased with my Farmtrac 675dtc (72hp). Check out the 775dtc's also.
Don't skimp on a 7' shredder, go 10' at least, been there made that mistake.
Good Luck, KB
/ New Tractor, 75HP Range #8
i agree, I have a 8' on my TN because I have to transport all the time (and I don't watn to deal with the whole oversize load thing) and it's barely working on that eight footer
Get a 10' at least.
/ New Tractor, 75HP Range #9
If price is not a big concern, then I would set on as many models as I could, because they are not all the same. One might feel great and everything is in the right place and another brand will be a little different and might not be as comfortable. This will vary from person to person. Just because I happen to like the way my machine is does not mean that you will. You really need to set in the seat yourself.
If price is a major factor, then start pricing and hope that you like the one that you can afford. If they end up close in price, then go back to the comfort thing. Be sure that you price apples to apples, otherwise it won't be a correct comparison.
After you think that you have a machine or two that your interested in, then come back here for more help and opinions.
Good luck :)
Thanks for all the replies. I don't anticipate doing a lot of cutting, as we'll be intensively rotating cattle for a grass fed beef operation. But there's always some bush hogging, and there's woods to clear, a creek on the property, a new pond, etc.
If I was to do some price shopping, what are the most comparable models to price against, for example, a JD 5205?
Kubota -
Mahindra -
NH -
Farmtrac -
/ New Tractor, 75HP Range #11
The JD 5205 is discontinued (some great deals available right now) and was a sort of mid-feature model. Most brands have either only one model or only bare-bones and deluxe. I would look deluxe if you have the funds. I would suggest Kubota M6040 and 7040, NH TN75, the JD 5225 and 5325 (both more deluxe than a 5205 but about the same size) and I don't know models from Mahindra and Farmtrac.
/ New Tractor, 75HP Range #12
Here is a place to start, some are a little lower hp & some are a little higher.
Massey MF5435
John Deere 5325 or 5425
Kubota - M7040 or M8540
Mahindra -7520
NH -TN75
Farmtrac 675dtc
Do some research on each of the manufactures websites, compare specs, go from there. Maybe go up or down a size? You need to look and compare
/ New Tractor, 75HP Range #13
I was going to buy a JD 5420 until I stumbled across a local Zetor dealer.
Over three years later and still happy with the purchase, excellent tractor, good dealer, and that $20K I did not spend on the tractor is now worth :D
Livestock chores may be more efficient with a skidsteer and/or a Gator.
Digging up rocks is best with a backhoe. Picking big rocks is easy with a tractor, little ones disappear under the nose. 10' bushhog advise is spot on unless there is clearance issues.
Clearing with a mulching SS makes for zero cleanup, I carved out a pond with my dozer last year.
How much free time do you have?
I never heard of Zetor...anyone else have experience with that brand? There is a dealer about 40 miles from me.
/ New Tractor, 75HP Range #15
Unless you are just dead set on spending a lot of money, you might want to look for a used Ag Utility such as a 10 series NH. Anything from 5610 on up would come close to your hp needs. I think you are correct in wanting enough hp, but in my opinion, the best combo of power/ease of manuverability falls in the 50-65 hp range. You should find numerous MF and NH Utilities in this hp range in your area, ranging from a few hundred to a few thousand hours. You can add a FEL.
What part of East Georgia? You might find a deal on a tractor used to pull peach wagons or peanut wagons. These usually have no more than 200 hours, full warranty, and a thousand dollar or more savings over new "right out of the box."
I hope we all get some rain out of this system coming in today and tonight.
/ New Tractor, 75HP Range #16
15 foot bat wing bush hog is what i would recommend buying for that size tractor. it follows the ground better than a 10.also can get closer to fence row with over hanging tree limbs
/ New Tractor, 75HP Range #19
You looking for new, used but new.. or used and older?
Your best value will probably come from use dbut newish tractors who are just barely broke in.. but have already taken the depreciation hit price wise.
other options are older used + a new CUT for probably the same ballpark price of a larger new-used unit.
CNH 56/66/7610s is a decent unit near your range.. lotsa county hi-way dept's use them. Same with the 5/6/7X40 40 series.
Soundguy
/ New Tractor, 75HP Range #20
lead_dog said:
What kind of deal value is this for a NH 75HP?
2006 NEW HOLLAND TD75D For Sale at TractorHouse.com
That's a pretty good price. A loader is another 5k.
I think new they are closer to 28/29 or so.
What kind of transmission? it doesn't say?
could be an 8x3 though and that's not so hot. I don't know what that big lever is by the front left, mine doesn't have that (i have a Power Shuttle)
2017 CATERPILLAR 305E2CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2022 John Deere 1025R (A53317)
2022 John Deere...
2024 KAUFMAN LOPRO WEDGE 3 CAR TRAILER (A59905)
2024 KAUFMAN LOPRO...
BUNDLE OF UNION STRUT COVERS (A60432)
BUNDLE OF UNION...
F -550 Bucket Truck (A61306)
F -550 Bucket...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
