New tractor filled tires?
   / New tractor filled tires? #51
Nitrogen in tires makes cars & truck go faster while getting better mileage
Nitrogen vs plain air gives a more consistent pressure in car tires, not that it's necessarily noticeable to most people. The reason is that normal air has water vapor in it; when the water vapor condenses, there's more contraction of the volume than that of an ideal gas undergoing the same temperature change - and similar in the other direction if there's actually liquid water being added to a tire (idk how, maybe someone didn't drain the air tank?) when the temperature goes up, because liquid water turns to a much larger volume of steam when the tire heats up. As I said, though, this really matters the most to racers, but it's a selling point, possibly slightly more legitimate than gold connectors for your fiber optic cables...
For tractors... ridiculous.
Especially when you're filling the tire with a bunch of water-based liquid!
   / New tractor filled tires? #52
if they could fly, it would be upside down. move those clouds with your box blade!
   / New tractor filled tires? #54
   / New tractor filled tires? #56
true we should just leave them airless - wait i did, i have a set of those ;-)
2026 Quality steel dump truck (A56859)
2026 Quality steel...
Air Compressor (A57454)
Air Compressor...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
4ft Quick Attach Disc Harrow (A57454)
4ft Quick Attach...
Sedan (A59231)
Sedan (A59231)
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
