New Tractor Fuel additive
   / New Tractor Fuel additive #21
It is a known fact that ULSD has less lubricity then the older diesel did, sulfur is a lubricant. Maybe these newer diesels don't need any additional lubrication, but for the cost of an injector pump I will continue to add something to my fuel, it could be a commercial product, or 2 stroke oil, or ATF. And my winter fuel tank definitely gets anti-gell as well.
Agree with Lou. Newer tractors are designed to run on ULSD but with temps that go below 0 deg F quite often I always add anti gel to my tanks.
   / New Tractor Fuel additive #22
I'm on my third new Kubota as of a week ago.......am and was a newbie to diesels as well as the advent of lead free gasoline for that matter.
I just re-read the OE manual for my new B2650 as to fuel statement by Kubota. My conclusion ............is that I'd have to be a petrol engineer as well as a Kubota Lawyer to really understand what it all means to me on a day to day basis, winter and summer .... this "marketeer" or that "marketeer". Day to day functionality and warranty considerations are beyond me as defined by Kubota....and other tractor manufacturers I assume.
Thus for the OP with the original red dye from the dealer, I'd run it out and try to purchase diesel fuel from a busy diesel station....then add some white bottle PS to each purchase, be it 5 gallons or 100 gallon....(each person has variable turn over of fuel). After 3 new machines and 10 years of service that has worked for me.
Cheers,
Mike
   / New Tractor Fuel additive #23
Doubt the fuel pump parts ever actually rub against each other.
Ralph
I just wanted to provide some information here, just so it's clear that there are indeed components within the fuel pump that rub against each other.
   / New Tractor Fuel additive #24
On a related note, how many ounces of white bottle power service do you add to a 5 gallon can of diesel?
   / New Tractor Fuel additive #27
I've been adding 2 oz per 5 gallon container....winter and summer....works for me. The white bottle say 32 oz per 100 gallons.....that would be 2 oz per 6.25 gallons..if I could figure correctly. PS says to double that if the temp is below 0 deg F.
   / New Tractor Fuel additive #29
The first batches of ULSD did lack enough lube however the refineries added more and the rest is history.
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
Hose Reel (A55787)
Hose Reel (A55787)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
378721 (A54865)
378721 (A54865)
