New Truck time
   / New Truck time #91
Diamondpilot said:
Pulling what, your kids little red wagon? No matter what pulling any load is going to affect mpg. Your dash is lying to you. Hitch up your load and start with a full tank of fuel then tow it 100 miles and fill up again and do the math. Pulling any load over 8, 000# you will be lucky to see double digest no matter what brand of truck.
Chris
You got me. I pulled it 100 miles. Yup, still 16.4 mpg. I don't have a tractor over #8000, should I put some rocks in it and try again?
Sent from my iPad using TractorByNet
   / New Truck time
   / New Truck time #93
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=292404"/>
Love it... lol
In all serious I have owned two GM trucks, a Toyota, nine Fords, a Dodge, and a Nissan. All 4x4 except one, and four diesel. These are all 1997 and newer and I drive about 20,000 miles a year in each and tow loads from 7,000# to 25,000# about 5,000 miles a year or more and track every drop of fuel for business purposes. Its just the way it works while towing.
Chris
   / New Truck time #94
14k backhoe on a 17.2k GVWR trailer behind a 8.8k GVWR F250= No CDL.
Still over capacity on the truck side.
I don't think there is a way to pull a backhoe by the books without scuffing some numbers or getting a CDL. Not to say people don't do it. Just putting the food out there for thought to investigate before you buy.
For my business I've had a couple SRW trucks because of not wanting to go over 10K gvwr because I've been told insurance goes up. I also can't park a drw easily around where I work and they suck offroad without having a 4x4. If I need to haul something heavier I just pay to get it delivered or in the case of a backhoe we just drive it around town.
   / New Truck time #98
Air brakes have nothing to do with it. Many RV's have air brakes.
Its true that if you are commercial you need a air brake endorsement but for non commercial it has no bearing.
Chris
Around here the same dump druck with air brakes requires a CDL, one without does not (at least that's the way it was a few years ago)...I have friends who played on that fence. Maybe the laws have changed over the last some odd years... Yes there were GVW issues involved and I have no intention of nearing those numbers with anything that I pull.
I'm aware that RV's are exempt...
   / New Truck time #99
You might be able to scuff some numbers and get by with a new SRWF350. You'd have to add the gvwr to the tow rating and use a trailer with 2 heavy duty 8000lb singles. It would be pushing it though on the tires, axles and ratings.
I say singles because around here I've known people popped for pulling a dual tandem with a SRW.
   / New Truck time #100
What, not WD, chains and anti-sway bars?...Living dangerously. :D:shocked:
I get similar empty mileage with my '11 GMC 6.2...Mind does around 12-13 towing depending on the what's and where's. I get about 1mpg worse with my gate trailers due to the drag.....I can live with that.
Swict 66" Bucket (A57149)
Swict 66" Bucket...
2022 BOBCAT T740 SKID STEER (A52709)
2022 BOBCAT T740...
2010 Toro Groundsmaster 3500-D Sidewinder 3 Deck Rotary Commercial Mower (A56857)
2010 Toro...
Quick Coupler (A57149)
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A58375)
UNUSED SDLANCH...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
