New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up
So I confirmed it has air tailgate.
Getting much cheaper shipping quotes.
Might still happen….
Ouch, that's sure as he** not cheap. Does it make you think more about going yourself to get it?
I can’t. It’s 1300 miles away and i’m working 7-7 everyday with hay.
If I can get it shipped for $1,500, will prob do it.
The condition of the bed looks to be about a 7 out of 10. Only thing I wished it had was a thick floor or AR450. Might leave me wishing I had waited, but used 12’ bodies in good shape are impossible to find.
Anyone of the opinion that the body is light-built, or light duty?
I don’t think its a Beau Roc or a real HD body, but I want to make sure it’s not 1 step above aluminum, either.
I found affordable shipping. Want to make a move, but really hesitant about how well this thing will hold up…
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #254
I've heard you talk about rocks being something that you're truck will see. What's the description? Some guys can have the loader put in a few small "dumps" of soil before dropping in the larger stones. Then I've seen what's basically an wood mat that's minimally screwed un from the bottom and definitely distributes the point loads you have dropping large rocks in a truck. The mat approach requires planning as sometimes it's hard enough to get a clean dump with just a smooth steel bed and a mat makes it worse.
That bed looks well built but "heavy duty" isn't something that a picture will tell you. 👍
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #256
That's going to be something that's hard to tell unless you're actually there to 'bang' on it.
One thing that does give me cause to think light duty is the hinge:
The actual ear is 1", 1-1/4" thick? any I've worked on are at least 2"-1/2" as well the cheek plates are 1/2"?
What are the bunks, channel or tube?
Definitely not a BeauRoc
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #257
This liner might be worth the investment, makes quite a difference.
I remember looking at them years ago and back then they weren't cheap. They're definitely slippery. I'd be concerned about the trapping of moisture between that an the deck.
I will have the opportunity to redo those when the body is mounted, but you make a good point.
I want to make sure it’s not a glorified mulch or sand body.
I have a sort of “nuclear option” of going in a completely different direction with the truck….
A little background: In the future, I wanted to buy a tandem axle with a 20-24’ flatbed for hauling hay. Was looking at IH7400 tandems.
I could put that plan on hold and build the IH 7500 4x4 with a 12’ flatbed. It could haul (6) 4x4x8 square bales on the bed and it has enough power to pull a flatbed trailer with 12 more 4x4x8 square bales on it. Would make a great hay hauling truck.
Would rather make this a dump and get the tandem for hay, but finding a used 12’ dump has proven more difficult than imagined.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #260
It would make a great hay hauler! But what about your g/n and the ram? I don't mean to be a kill joy but that's a killer hay mover also and I kinda get the idea that you mostly work alone.
Do you have a good bumper pull for behind the IH? I remember you pictured one you were looking at.
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
2008 Chevrolet Uplander LS Van (A55853)
2008 Chevrolet...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
