new/used/rebuilt engine needed for JD 4100
   / new/used/rebuilt engine needed for JD 4100
Hi all. I have then frame split and the oil pan off. The center (damaged) rod and piston out. The piston is destroyed. The rod to me looks ok and the rod to crank bearings look ok to me. But I really don't know what to look for.
Does anyone know if the cylinder can be overbored and a liner installed? What else should I do?
If I put in a liner and the same size piston, would that cause an imbalance?
   / new/used/rebuilt engine needed for JD 4100 #93
A bent rod would give you vibration.
Depending on what caused the damage to the piston, you could also have damage to the valve train somewhere, also causing you vibration.
   / new/used/rebuilt engine needed for JD 4100 #94
I would take the block to a machine shop and let them measure the bore to determine if it can be bored out. If the damage is greater than the maximum allowable bore size then a sleeve can be installed. All three cylinders will have to be made the same size so if one needs bored out they all will need to be made larger.
On the phone one shop mention that if one cylinder is bored the others might change shape and would also need to be bored.
Going to have a couple mechanic/shops look at it
One opinion says space between cylinders is two narrow to machine for a liner. New block is preferred. JD block is $2700; JD short block is $4700. Thoughts on where to find a block or short block?
https://www.ebay.com/i/253177166592...1291&msclkid=8d3ca63b1fca11a01497f9086ff7b2ca
Search results for: '3tne74' (assuming they are in De Sota, that's about 200mi for me)
any others?
I guess at this point I'm shooting for $2500 to get the engine back in working order. Gut feel, $750 block, $750 pistons, rings, etc. $1000 labor.
   / new/used/rebuilt engine needed for JD 4100 #99
If you are interested in engine replacement I always recommend TBN member "Bruce1966us" . Bruce Laten is located in Lynchburg TN and I have always felt his engine and shipping prices to be the best around. You can contact him through Ebay bruce1966us on eBay I think his number is 931-492-0316. He carries a variety of different brands of low hour Japanese diesel engines.
Thank you! I'll be making that contact today. If I can find a known good condition engine in that price range, that's the solution.
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
2026 tilt trailer (A56859)
2026 tilt trailer...
CATERPILLAR 313FL EXCAVATOR (A60429)
CATERPILLAR 313FL...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
