Newbie looking for critique
   / Newbie looking for critique #61
Best to practice with similar scrap metal before making any welds on your project.
Always easier to weld it only once, Unwelding and redo can be a uuuge nightmare.
Grinding out inside corners and inside 90’s is a great way to make more scrap. Always tack things in areas easy to grind out if adjustments are needed.
   / Newbie looking for critique #62
I didn't show you my welds close up because they're not pretty but they are strong and I have lots of advise and need plenty of practice.
That's why I call my welds Gorilla welds, ugly, but tough.
   / Newbie looking for critique #63
So long as it holds. Honestly, sometimes there's just too much fussing on this here board about welds. OMG, I see 2 pin pricks in your weld, you got some porosity...go kill yourself! I mean, so!?? Unless you literally have zero penetration, yeh that's bad, but otherwise your ugly weld will hold. Especially guys like us with the little scuts, if your weld will bust on an implement for them, likely the material you're welding would bust too.
   / Newbie looking for critique #64
I feel the same way. I just want my welds to hold. If it's something where appearances matter, grinder, die grinder, and paint will fix me right up.
All welds have black lipstick with a red hat. Thanks to all for your critiques and suggestions. It's members like you what makes this site so great.
   / Newbie looking for critique #66
Pixguy, we have an opening in the welding bay….;)
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
(2) USED 3500 LB IDLER TRAILER AXLES (A57192)
(2) USED 3500 LB...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
INTERNATIONAL EAGLE ROAD TRACTOR (A57192)
INTERNATIONAL...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A57024)
2023 Top Air ATV...
