Newbie
   / Newbie #11
I was told the only difference is diesel is dyed and taxed therefore I did install a hand pump my friend gave me right into my home heating oil tank which is located in my garage right where I park my tractor.
woody
   / Newbie #12
The only difference in Ontario between "stove oil" and diesel fuel is dye and about 20 cents a litre in tax. I think Quebec is the same. The dye is there to catch people fueling on road vehicles with tax exempt fuel -- if you go to a gas station that sells both (some country ones still do) ask them -- they will tell you the same thing.
P.S. -- the dye won't harm your tractor!
I now have one of those little reciever hitch carryalls ($50 at Princess Auto or Harbour Freight) to carry gas and diesel from station to home. It keeps the odour outside the vehicle and SWMBO happy:)
Oh and yeah -- diesel fuel will gell and they do switch between summer and winter by extracting more moisture -- but they do it for stove oil anyway. I know having once had a fleet of 170 ton trucks shut down because our fuel supplier shipped the wrong season fuel:( (it was always dyed) -- needs to be pretty cold to do so (mustache freezes after a minute outside)
   / Newbie #13
Well if ou know what you are getting for home heating oil then you are ok the problem is they can substitute many different grades for HHO.
Home Heating Oil / Fuel Oil #4 and Home Heating Oil / Fuel Oil #6 have a higher BTU content. This is normally accomplished by adding much heavier petroleum oil distillate similar to automotive motor oil to the formulation. This allows a furnace to burn less fuel, for each BTU of heat produced, as well as often times reducing the cost per gallon of fuel. These types of Home Heating Oil / Fuel Oil should NOT be used in a Diesel Fueled Engine or Generator.
In times of shortage, Standard Road Diesel #2, Diesel #1, Kerosene, K-1, Jet Fuel, JP-1, Agricultural Diesel, Diesel #2, Home Heating Oil / Fuel Oil #4, or Home Heating Oil / Fuel Oil #6 may be shipped by fuel distribution companies and sold for use as home heating oil. There may also be times that, due to economic and other considerations, fuel distributors sell any or all of these products, or combinations and blends of the same, to home owners, as simply Home Heating Oil / Fuel Oil.
SUMMARY: Home Heating Oil / Fuel Oil #2 and Off Road / Agricultural Diesel #2 seem to be very similar products. More importantly, Home Heating Oil #2 is refers to a very specific product, and a very specific formulation, which, in many cases, may be a very similar product in terms of composition and formulation as Off-Road Agricultural Grade Diesel #2.
Take a chance with your nice new tractor if you like
Frank
   / Newbie #14
Frank -- thanks for the clarification.
Locally some of the gas stations have two pumps, one marked diesel and the other marked stove oil -- the stove oil is there as a convenience to people who run short of fuel oil and to folks who do not have ready access to offroad diesel. I believe it is #2 heating oil but will check next time I am in. If you pull up to fill up a container, they will ask what it is for and if you say tractor, they will direct you to the stove oil pump (@ 20 cents a litre less):)
By the way my gelling problem was from a refinery in North Eastern BC and it was about -35 c or more for a couple of days. It is definitely not fun trying to drain fuel systems in that weather:(
   / Newbie
Well thank you all for the great info, at least now I know and am informed! They didn't deliver my tractor on Friday as they stated......hopefully will get it soon, I've gathered a ton of great ideas from you all and ready to start doing some very useful modifications.............can't wait, I'll post pics when it arrives!:)
   / Newbie #16
mean,
The best thing to do is ask you HHO supplier. They will be glad to tell you what they use as HHO. That way you will know what you have in your tank and you will know if you want to put it in your tractor.
   / Newbie
Well I finally got it last Friday, been having a ball with it, can anybody tell if there is a difference between an 07 and a 08 model? Other than price? They brought my snowblower but the delivery guy said I will have to cut the shaft for proper fit.....I told him where to go for a hike, and that they better come and install it properly and that it should of been done prior to delivery......but none the less I'm having fun with it!!!!
   / Newbie #18
If your 1528 is the gear model, it is the same for 2007 & 2008. The Hydro model has the new style foot pedals two pedals side by side, instead of a single rocker pedal.
Congrads, and enjoy the new tractor! Great choice.
   / Newbie
Ahhhhhh right on! It's the Hydro with side by side pedals and the brake pedal on top which seems a little awkward but will get used to it! So far very happy with it... Thanks
   / Newbie #20
Nice tractor! -- by the way have you found out that the heat and diesel fumes really attract black flies and other biting pests:D Even so you will wonder why you took so long to get a tractor after you start using it.
regards
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
JOHN DEERE 544G WHEEL LOADER (A58216)
JOHN DEERE 544G...
2019 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2019 John Deer...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
PALLET OF BANNISTER RAIL KNOBS (A58374)
PALLET OF...
