Newly assembled trailer: one hub warmer
   / Newly assembled trailer: one hub warmer #31
gotcha... yep.. lookls like climbing under it is SOP.. :)
soundguy
   / Newly assembled trailer: one hub warmer #32
I pull it with an SUV but the real benefit is that it folds up and stores easily inside on the side of the garage. It has 2 inch casters that i will replace with 3 inch but it does roll and is manageable by one male Capacity is about 900-950 net which is fine for dump runs or collecting Craigslist bargains without the hassle of going to and dealing with Uhaul.
The only real downside I have found so far is that once you put a deck on the bed you must crawl underneath to install and undo four bolts that secure the trailer in it's unfolded position. I may have to figure out a more convenient locking mechanism.
I remember that with the one I assembled. I got some short pins and clips instead of the bolts. They were maybe 3/8" diameter and about 1" long. A short stack of washer snugged them up to the clips. They were just miniature versions of top link pins used on the 3 point.
It never really flopped around because of the weight of the wood and the load you may be hauling.
Chris
Yeah I think I can use hitch pins for the lateral bolt I just need to figure out something to relieve upward pressure on the hinge without crawling underneath. Maybe I can weld a bracket on the outside to make bolting it down more accessible.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2016 Volkswagen Jetta (A56859)
2016 Volkswagen...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
3PT HYD HAY FORK (A52708)
3PT HYD HAY FORK...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
