NH68 feed "rice fork" hitting frame
   / NH68 feed "rice fork" hitting frame #1
petebert
Outside of Ann Arbor
The red feed fork is hitting the frame on the downward stroke. Bandaid fix would be to cut a notch where it's been hitting. Any ideas for an actual fix? There's a nut pictured below on top of the rail that the feed forks are on. I found that completely loose. If I tightened that I could see it raising it a couple millimeters. Maybe a couple more if I replace the roller bearings. Aside from that I don't see anything to adjust.
After posting this I researched it some more and have a theory. I actually have a 2nd problem also, the feed fork bar is hitting the machine at the top of it's stroke also. While looking into it more and seeing pictures of other peoples balers I noticed the spring loaded bar at the end of mine sticks out further than on other peoples. I don't see anything in the manual on the correct distance to set this thing at but am thinking if I wipe all the junk off of it I mind find a mark or at least a rust line from where it previously sat.
   / NH68 feed "rice fork" hitting frame #3
Maybe. Thank you for the information. I am not an expert but your words make sense.
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
2018 Trail King Lowboy (A56438)
2018 Trail King...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
