Nice Pics of the New 2005 B-3030 & LTB-39
   / Nice Pics of the New 2005 B-3030 & LTB-39
Most of the industrial and commerical turbodiesel designs utilize wastegated turbos that only produce a limited about of boost, ie less than 8psi since they do not have intercoolers to lower the compressed air charge temperature. The wastegate is set to open and vent off excess turbocompressor energy or there is a blow off valve in the turbocompressor-intake manifold line. For that kind of boost there is less worry about excessive power output and elevated EGTs, so indeed that would be the most feasible.
   / Nice Pics of the New 2005 B-3030 & LTB-39 #82
Jay,
Kubota's Glideshift (GST) transmission DOES use a hydraulic forward-reverse shuttle. It also uses a hydraulic auto-clutched gear selector that allows you to select speed or direction without clutching. At least that's the way the one on my friend's Grand-L3010 works that I have operated on several occasions.
It's a pretty convenient shifting mechanism.
Taken from “New Features of the Kubota Grand L30 Series Compact Tractors”
The Glide Shift Transmission (GST) is original Kubota technology which provides 12 forward and 8 reverse shift-on-the-go gears without the need for clutch operation. The GST has a hydraulic clutch and transmission gears that are changed by the action of an actuator located in the transmission. When the operator initiates a gear change, the GST automatically performs a series of operations that includes disengaging the hydraulic clutch prior to the gear change, changing the gears and then engaging the hydraulic clutch after the change.
The ECU allows for a single shifting lever that actuates a potentiometer signifying the specific gear selection. In the Grand L30 series tractors, the ECU controls a proportional pressure reducing valve, solenoid valves, and performs a gear change by operating a hydraulic clutch.
With this GST system the pressurization of the hydraulic clutch can be set by a proportional pressure reducing valve for limitless stages, all of which is controlled by the ECU. The tractor is equipped with an engine tachometer sensor and a travel speed sensor, as well as a potentiometer that distinguishes the position of the gear selection lever. Based on digital signals from the engine tachometer sensor and the potentiometer, travel speed after the completion of a gear change is calculated, while the travel speed sensor calculates the actual travel speed. Based on the difference between the two speeds, the pressurization characteristics of the hydraulic fluid supplied to the clutch is set. Thus the Kubota GST brings about a smooth gear change by changing the pressurization characteristic in response to the various patterns of gear operation.
Acceleration of the tractor is calculated based on digital signals from the travel speed sensor. Under conditions when the tractor accelerates rapidly, the pressurization is changed to become slower during the pressurization process. When the tractor accelerates slowly, the pressurization is changed to be more prompt.
After the hydraulic clutch begins engaging and the acceleration of the tractor starts, the acceleration is calculated and the pressurization characteristic is compensated. Tractors may be equipped with a variety of different implements according the context of work users wish to perform. In particular, when an extremely heavy implement is attached to the tractor, acceleration does not occur until the compensation begins, which makes gear change time much longer. Therefore the compensation of the pressurization characteristic based on the total tractor weight is realized. The offset can be input using the “Adjustment Mode” of the IntelliPanel, with the correct offset stored in ROM. The ECU of the GST takes in the correction value by communicating with the ECU of the IntelliPanel and compensates the pressurization characteristic. The offset is just a derivative of the diameter of the tractors tire diameter.
   / Nice Pics of the New 2005 B-3030 & LTB-39 #84
Skypup,
Yup, that's a very detailed description of what I summarized above. While I'm sure they improved on the GST mechanism between the L3010 and the later Lxx30 models, the basics of it from an operator's perspective I would expect remain similar.
JayC had asked whether he saw a shuttle-shifting lever near the steering column, and I was confirming that, yes he had. The GST transmission is operated via a forward-reverse direction selector, a range selector, and a gear selector. The actual electro-hydraulic-mechanical mechanism best desribed as you have via the company's detailed statement.
thanks,
   / Nice Pics of the New 2005 B-3030 & LTB-39 #85
Jim,
I had an L35 and always moved it from the BH seating position. I would reach back and place it in low gear and push the lever forward or back to move the machine. Never had a problem with it but you should be careful of course. This is not the same as JD but the outcome is the same.
I now have an L48 and reach back and down to the tredle peddle to move the machine forward and backward. It is not as easy as one would like but it works and is far better than getting up and rotating the seat to move to the loader seating and move the machine then rotate back to do the same thing again. It is not in the manual but lots of things aren't that work. Just be careful.
   / Nice Pics of the New 2005 B-3030 & LTB-39 #86
Ron,
I'm also thinking about the 3030. Cab or not?
   / Nice Pics of the New 2005 B-3030 & LTB-39 #88
I would be lost with a cab myself, but my weather is mild enough to not consider one. I also have to many trees that would show me how you remove the cab without using tools. I asked the question once why would folks want a cab. It seemed our eastern and midwest TBN'ers did not understand the question. /forums/images/graemlins/grin.gif, really. I think it has something to do with the cold of winter and hot, humid heat in the summer.
   / Nice Pics of the New 2005 B-3030 & LTB-39 #89
Not?
It would be in my way.
If I was cutting lawn all day or blowing snow. A Cab would be great.
By the way. At this time a BH will not fit Cab model.
   / Nice Pics of the New 2005 B-3030 & LTB-39 #90
I think Rat's trying to tell us that his weather conditions are generally superior to those folk in the midwest and east. No need for such a silly thing as a cab......He is correct.
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2016 JOHN DEERE 3032E LOT NUMBER 97 (A53084)
2016 JOHN DEERE...
JOHN DEERE 17P LOT NUMBER 241 (A53084)
JOHN DEERE 17P LOT...
2020 Isuzu NPR Garbage Truck (A52377)
2020 Isuzu NPR...
