No Kohler spark...EVERYTHING replaced - HELP!
   / No Kohler spark...EVERYTHING replaced - HELP!
Is your coil well grounded to the engine block? Clean shiny metal under the bolts that hold it to the block? If the coil mounting holes are covered with fresh paint then it could be insulated from the block- and the circuit would not be complete.
Good thinking...checking it now.
No luck...Didn't help. I thought you solved it considering that the new coil has a clear coat on the metal.
   / No Kohler spark...EVERYTHING replaced - HELP! #33
NEW TEST RESULTS: I went out and re-checked the air gap and tweeked it. Poof - I have a spark! Then I screw in the plugs, try to start it and nothing. I re-check the spark.....GONE!
So when you try to start it does it wet the plug?
Not wet but I even sprayed starting fluid without even a pop.
   / No Kohler spark...EVERYTHING replaced - HELP! #35
Kohler service schools always told us if you don't use a good spark tester you run the risk of
burning out the electronics inside the coils. There's a lot of voltage and if it doesn't discharge
properly it will cause damage. I have never replaced a flywheel due to low,weak magnetism.
I FOUND IT !!!!!!!!
I'm surprised that nobody thought of this one: I initialy thought the coil was bad and bought a new one. When that did not fix it I bought a new flywheel...What if the first coil was always good and the flywheel was bad, then you were sent a bad coil? That was it; Put on the old coil with the new flywheel and its a sparkin fool! Started right up first crank.
I even got the retailer to send me a new coil based on all of this talk. THANKS to everybody for their help....Now lets cut some grass!
   / No Kohler spark...EVERYTHING replaced - HELP! #37
Glad to hear it! It does really mess up the troubleshooting process when new parts are defective...
   / No Kohler spark...EVERYTHING replaced - HELP! #38
Hi everybody...I'm new here with a problem that is driving me over the edge. I have a Scag 48" zero turn that is not running. It has always been finicky but now has died with no spark. The engine is an older Kohler magnum 18hp twin cylinder with coil-magneto / flywheel ignition. First I checked the coil with a meter across both both secondary wires and found it completely open. New coil installed...It has a very weak spark that will not bridge any spark plugs
I FOUND IT !!!!!!!!
:confused3: ... Probably just read what you wrote.
larry
   / No Kohler spark...EVERYTHING replaced - HELP! #39
Great, glad you got it fixed. I know briggs will remagnetize a flywheel for free. I dont know about kohler. Might be worth asking.
I wont need it after buying the this one, but worth checking in the future. Thanks
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2007 International 4400 2,000 Gallon Water Truck (A52377)
2007 International...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
