No Spark to plugs...please read and help
   / No Spark to plugs...please read and help
If you were close, I'd help you out for some brats, beer, and sweet corn. Your too far away for some grub though. I can't believe you can't get a old school points guy to help you in your area. I wish you luck...
Much appreciated! I surely have no shortage of beer, brats, and sweet corn for anyone that wants to help. I may have been a little dramatic, I don't want a lawn ornament so I'm still going to try and find someone to help me out.
   / No Spark to plugs...please read and help #82
Dont give up! If it ran before, it should run again.
Beer, brats and corn :thumbsup: wish I was closer.
Check the distributor, if in dought, pull it and recheck the gear,maybe it sheared the pin?
If you have the original coil, reinstall and try it first.
I don't really want to mess with the distributor any more. I had a service tech come to the house and set the timing. I can only assume hedid it correctly. He couldn't get it running either. He did manage to burn up my starter motor though...but it was only a matter of time for that anyway.
   / No Spark to plugs...please read and help #84
Gotta' agree with the old timer suggestion. I've got a guy who's older than dirt who will come on a moments notice fix the problem and charge me $50.00. I usually get an education in the process.
   / No Spark to plugs...please read and help #85
I hate to hear that your giving up when your so close. Don't take offense at this but do you realize that the piston is in the up position twice? once for the exhaust stroke (exhaust valve open to expel hot gases) then on the down stroke the intake valve opens to bring in gas and air mixture) Once for the compression stroke where both valves are closed and the piston compresses the gas mixture and the plug fires when the piston is at TDC or "top dead center" Do you know how to tell when you are in each state? Sometimes we tend to overlook the simple things.
You mentioned that your tractor ran for a while and then stopped again. Are sure that the gas shut off valve in not in the off position but is leaking just enough gas to get you started but then runs dry? In cars we are not used to turning the gas off and on like that, but tractor guys do. One way to figure this out is to turn the knurled knob at the bottom of the sight glass and remove the bowl. Empty it. Replace it. And if it is off and leaking it will fill up drop by drop until full. If the valve is open when you remove the bowl it will flow like a cow urinating on a flat rock. Have someone flip the valve the other way to off and replace the bowl.
Don't give up. We're all wanting you to succeed!!! And you really don't need another yard ornament...
Remember Thomas Edison tried 664 times before he found the correct material for the filament of the light bulb. Where would be if he had stopped short?
Best of luck,
Ford851:thumbsup:
   / No Spark to plugs...please read and help #86
hit it again.
if you can get spark, then try starting her on starter fluid.
if not getting spark.. hot wire a coil.. ie.. power to coil to dizzy. then make sure dizzy spins with engine.. and points open, and are not shorted.
not much more to a kettering ignition than that.
hit it again.
Ive done all this about 3 times. Thanks tho.
   / No Spark to plugs...please read and help #88
start from scratch.. you are missing something.
there hasn't been anything new under the sun on a basic breaker points system accomplished since that tractor was new.
   / No Spark to plugs...please read and help #89
If it ran good for thirty seconds you probably have the ignition fixed. I would take the gas line off the carb and see if you have a good flow of gas. Old tractors get rust and crud in the tank that stops them. I just fixed the tank on my 1941 MM for that reason.
Yea, I took the carb off and cleaned it. It was pretty clean. Also there was plenty of flow from the tank to the carb via the tube. New gas too. Well, going on 3 weeks now.
2002 POLAR TANK (A58214)
2002 POLAR TANK...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
2017 Liebherr L566 X Power Articulating Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel (A59076)
2017 Liebherr L566...
Case W7 Wheel Loader (A55272)
Case W7 Wheel...
John Deere  6125 (A57148)
John Deere 6125...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
