normal operation of a rotary cutter?????
   / normal operation of a rotary cutter????? #51
We have coyotes all over Ohio, too. I am wondering if someone can tell me the difference between a RFM and a rotary cutter?
   / normal operation of a rotary cutter????? #52
   / normal operation of a rotary cutter????? #53
roxy,
A RFM is a rear finish mower that mounts on the three-point hitch of a tractor. It is a mower designed to mow a yard or lawn. A rotary cutter is a heavier mower with blades made to swing back if they hit a solid object. A rotary cutter is designed to cut not only grass but also brush. One of ways a rotary cutter is rated is by the size of brush or small trees that it is capable of cutting down. This is a pretty simplified explanation, but should give you an idea about them. A finish mower will give a better cut, but won't cut brush.
   / normal operation of a rotary cutter????? #54
roxy,
   / normal operation of a rotary cutter????? #55
The RFM will have three blades that are thin and fast and look and cut like lawn mower blades where the brush hog swings two 1/2" thick x 3 or 4" wide bars around to pulverize anything in its path.
   / normal operation of a rotary cutter????? #56
   / normal operation of a rotary cutter????? #57
Different finish mowers may have more or less than 3 blades.. same with rotary mowers... 2 blades per carrier.. etc..
Same premise though..
Soundguy
   / normal operation of a rotary cutter????? #58
Soundguy
   / normal operation of a rotary cutter????? #59
Boy soundguy, you are catching all kinds of my screw ups today. Keep me in line.
Another point is that a RFM will typically cost more than double an equivalent RC. Surely there are exceptions but they are much more expensive.
   / normal operation of a rotary cutter????? #60
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2015 GALYEAN 180 BBL STEEL VACUUM TRAILER (A52472)
2015 GALYEAN 180...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
JOHN DEERE TS LOT NUMBER 151 (A53084)
JOHN DEERE TS LOT...
STORAGE FEES (A52577)
