normal operation of a rotary cutter?????
   / normal operation of a rotary cutter????? #51
We have coyotes all over Ohio, too. I am wondering if someone can tell me the difference between a RFM and a rotary cutter?
   / normal operation of a rotary cutter????? #52
   / normal operation of a rotary cutter????? #53
roxy,
A RFM is a rear finish mower that mounts on the three-point hitch of a tractor. It is a mower designed to mow a yard or lawn. A rotary cutter is a heavier mower with blades made to swing back if they hit a solid object. A rotary cutter is designed to cut not only grass but also brush. One of ways a rotary cutter is rated is by the size of brush or small trees that it is capable of cutting down. This is a pretty simplified explanation, but should give you an idea about them. A finish mower will give a better cut, but won't cut brush.
   / normal operation of a rotary cutter????? #54
roxy,
   / normal operation of a rotary cutter????? #55
The RFM will have three blades that are thin and fast and look and cut like lawn mower blades where the brush hog swings two 1/2" thick x 3 or 4" wide bars around to pulverize anything in its path.
   / normal operation of a rotary cutter????? #56
   / normal operation of a rotary cutter????? #57
Different finish mowers may have more or less than 3 blades.. same with rotary mowers... 2 blades per carrier.. etc..
Same premise though..
Soundguy
   / normal operation of a rotary cutter????? #58
Soundguy
   / normal operation of a rotary cutter????? #59
Boy soundguy, you are catching all kinds of my screw ups today. Keep me in line.
Another point is that a RFM will typically cost more than double an equivalent RC. Surely there are exceptions but they are much more expensive.
   / normal operation of a rotary cutter????? #60
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
378568 (A51573)
378568 (A51573)
