Nortrac???
/ Nortrac??? #1
snorider
waterford mi
nortrac
Has anyone heard of these Tractors. They are on northern tool .com I was looking into them and just woundered how they were.
/ Nortrac??? #2
Use the "search" function and you will find lots of info on Nortrac.
Mark
/ Nortrac??? #3
They are Chinese made Jinmas, which come under all sorts of labels, like FarmPro, etc.
Check out the Chinese Tractor forums for more indo.
Odd thing, the last I checked, a comparable machine cost more than my JD... Like anything, it pays to check all angles...
/ Nortrac??? #4
I investigated them a couple of years ago, before I invested in a Kubota. I found that after equipping it with a loader it wasn't that much cheaper than the basic L series kubota. Also, the craftsmanship of the tractor seemed to be inferior to the mainstream tractors. I remember thinking how small the hydraulic cylinders looked on the loader.
But, of course, it's all what you plan to do with it. If mowing is your primary activity.. or dragging a box blade.. then it could be all you need.
/ Nortrac???
I main thing I would use it for is snow removal on a paved driveway that is about 100' long and 60' wide. then pull the trailers out of the back yard. which is to small for a truck and they are too heavy for anything under a 600 cc four wheeler and thats working it. so I need a small tractor prefurbly used one.
/ Nortrac??? #7
NorthernTools enjoys a very good (and probably well deserved) reputation for competent tractor assembly and responsive support after sale. Can't amplify on that though without knowing which tractor(s) and implements you're interested in, and what you'd intend to use one for.
//greg//
/ Nortrac???
I was looking at a FEL and back blade. About how big is this tractor length wise. Does any one have a pic of one with something for scale. the reason is it has to pull the trailers out of the back yard and it is tight back there. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
/ Nortrac??? #10
Well, these are not your typical sizes CUT (Compact Utility Tractor). Mine is a Jinma 224 with the bigger tires like the 284. The only size difference between mine and a 284 is about an inch or two if that even though the spec sheets show different. I measured my lenght with a Koyker FEL from front edge of bucket to rear edge of 3pt arm and get 12' 7" soooooo when you add something like a back blade they ain't exactly short but I get around pretty tight places. Lets see if I can add a pic if size permits. /forums/images/graemlins/wink.gif Nope, tried a pic but file too big. Then again take a look at the pics on my Webshots page to get a idea of the size. Link below.
http://community.webshots.com/user/harrygoodwrench
/ Nortrac???
wow bigger then I thought. but still might be okay. how many HP is yours. If I get one From Northern tool It has to be put to gether right?
/ Nortrac??? #12
Mine is a 22 HP like in my previous description of 224. That means 22HP, 4WD. A 284 would be 28HP,4WD, etc.
Like I said, they ain't small tractors. Northern only sells assembled units to my knowledge. The NT 204 (20HP, 4WD) is a little shorter than mine,not much though, and has smaller tires. It is a tad smaller but not a lot.
I got mine as a crate unit from a dealer and assembled myself. Dealers sometimes sell as crate form but mostly assembled.
/ Nortrac??? #13
Northern Tool ships them assembled. You might also want to look at Farm Pro. They are the same machines, different sticker on the side. Both are made by Jimna. If you dig around, you can find "crate" specials on these where you actually put them together yourself. As I understand the crate deals, most of the tractor is assembled.
I noticed one thing that you might want to consider, you said you'd be pulling on the lawn. The "R1" ag tires will really leave some nice marks in your lawn if your soil is moist. And if your soil is moist and has a high clay content then those marks will turn into ruts that will harden like concrete. Just something to be aware of before you pull a trailer over wet grass.
/ Nortrac???
what dealers sell nortrac, farm pro, etc. tractors. The crate idea seems good do you save any money? How do you find a dealer. I have not looked up farm pro though only nortrac and all leads back to northern tool. as for the tires no worry there hard ground and not that nice of lawn anyway. thanks for bring it up though. /forums/images/graemlins/cool.gif
/ Nortrac??? #15
The NORTRAC name is owned by Northern Tool. You won't find anyone else selling that brand. But the tractor is Jinma. Do some searches for Jinma or Chinese tractor or Farm Pro or Agri Cat. Those may turn up dealers in your area. Also you might want to go to the Chinese Tractor Forum here on TBN and ask for advice from guys who have already puchased these.
One thing I would stay away from is trying to import your own tractor or working directly with a company in China. You can do it, you will save a bit more money, but you may end up with more grief than you anticipate. Some deals go smooth, some take months. I used to import containers of flavored water from Australia and about 20% of the containers would get stuck in customs. It was a paperwork nightmare. And that was for fully loaded sealed containers. Bringing in one tractor on a container of mixed goods is possible, but I would not want to mess with it.
/ Nortrac???
well that explains why it all went back to northern tool. I am looking into one of those inporting companies. would not even think about inporting myself. they look as if they are desent tractors. thanks for all the help everyone. /forums/images/graemlins/cool.gif
/ Nortrac??? #17
Snorider...Give us a call and we'll take care of you. 1.800.521.0438 Option 1 for Sales..Thanks /forums/images/graemlins/smile.gif
/ Nortrac??? #18
Snorider, I would think its better to buy from a dealer. Warranties are a lot easier than the import route. Just my opine.
Perry, it would be nice if you filled in your bio.
/ Nortrac??? #20
I decided to get my 204C from Northern Tool. There are many very good dealers posting in this forum. My main reason for going with NT was the free shipping since pricing was close and I do live in the sticks. I did get the FEL and box blade. If your still interested in the overall length I can take a measurement for you. I also see NT is selling a turf tire set as an option now. I'll probably order a set of those after the Christmas season. I did look at a JD about the same horsepower and options, but it was nearly $4k more. Much fancier tractor, so you do sort of get what you pay for. I'm very pleased with my purchase. Mine is the right tool for what I do with it.
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
SDLanch SDLGM1220F (A60463)
SDLanch SDLGM1220F...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
159115 (A60430)
159115 (A60430)
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
