NX5510 radio plug?
   / NX5510 radio plug? #11
I JUST bought a nice ck2510 with dealer installed field cab The nice cab is complete with lights, heater, wiper and even the radio speakers but no radio. Anyone know approximate price of a Kioti cab radio? Is it feasible just go to the junk yard and pick a radio from an auto and install?
rs
   / NX5510 radio plug? #12
rs
A factory radio price would probably give you a heart attack. I know one from LS did. I bought a new aftermarket universal compact digital AM/FM/CD radio from an auto parts store for about $59. and wired it in very easily. Unless you get an older junkyard radio most of them are now programmed to the vehicle vin number somehow and wont work if put in another vehicle without a dealer to program it.
I ordered mine off amazon for 49 bucks, it's a marine radio with AM/ FM / Weather band, USB, SD card, and auxiliary in. Oh and a remote :) I didn't want blue tooth or dvd, but you can get those if you choose to for a lot less than a factory one.
   / NX5510 radio plug? #14
This is what I installed in my NX4510HST Cab. Pyle PLMR19W Marine AM/FM/USB Radio - Walmart.com Same unit is available from other vendors and at Amazon, but WalMart had free store pickup and an easy return policy if it didn't work out. I figured for less than $50, I'd take a chance, as it has the weather bands for NOAA weather radio that I wanted. Turns out it's a nice little radio, with good sound and reception (hey, it's going in a tractor!). To pull the weather band in a bit better in my area I made a small antenna for it to screw into the factory antenna base after consulting with a radio communications buddy on the best length to match the wave length. That might not be necessary elsewhere.
   / NX5510 radio plug? #15
THAT link supplied by three point flew me right to the radio. The radio happened to be on sale for $46.00 plus I got a concealed antennae for under $5.00. It ended up costing me about a dollar to have it shipped righit to my door. I'M THINKING their shouldn't require any extra programming to connect tihe radio to this field cab as a wiring plug and speakers are present. Thanks for the help.
rimshot
   / NX5510 radio plug? #16
rimshot
If the field cab's factory plug is the same as on the DK and NX series, you are not likely to find an adapter. You can (1) snip off the factory plug (leaving a couple of inches of wire attached in case you ever want to replace it) and make the connections directly to the radio's harness with small wire nuts or better, or (2) do as George2615 did and crimp small spade clips to wires spliced into the Kioti harness without snipping off the Kioti plug, then plug the spade clips directly into the radio's connector. I'd considered doing the latter but was a little concerned about the integrity of my splices down the road.
Good luck with this. Do you have a link for the concealed radio antenna that you ordered? Iet us know how it works with the VHF weather bands once you get it installed. I gather your field cab did not come with a factory antenna.
   / NX5510 radio plug? #17
I pulled another swithicheroo and ordered a concealed antennae with free delivery on EBAY. It cost me $3.80 complellte;
Boss Audio Car Audio Video MRANT10 Dipole Hideaway Marine Antenna | eBay
Then I bought a seller refurbished radio with free shipping and a 30 day guarantee for $42. I;m not so sure I would have taken the thing if I hAD reAD the whole listing to discover it had been refurbed by dealer but I have 30 days to send it back. There are hundreds of these Pyle Marine radios on EBAY and they are all or nearly all) refurbed by Manufacturing. I am not too concerned
aboout non working stuff but we will oon see. I will have it in a week and will report back.
Pyle PLMR18 Marine Boat ATV Am FM Radio Player Radio SD USB Aux Receiver Remote 068888889186 | eBay
rimshot
   / NX5510 radio plug? #18
Yes the is a plug best buy has them
   / NX5510 radio plug? #19
Best buy this is plug fits nx series
   / NX5510 radio plug? #20
Bobfarm41, thanks for this, and welcome to TBN! I pulled up the manual for that plug on the Crutchfield.com website (pdf attached below), and from the diagram it indeed appears to mate to the Kioti plug on the NX series, with corresponding terminal functions, plus has some additional terminals that would not be used by the Kioti harness. Have you confirmed this with an actual installation? I ask because things sometimes aren't what they appear from the import manuals.
  • Turbo Wire plug manual 120707712.PDF
14ft. Deer Gate (A53424)
14ft. Deer Gate...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
Informational Lot - Financing (A55315)
Informational Lot...
2014 MACK CHU613 DAYCAB (A55745)
2014 MACK CHU613...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
