O-Ring material
/ O-Ring material #11
Zebrafive said:
That is the reason for this post. To get educated on which will serve me better, Buna-N or Viton. Buying bulk will be less expensive than buying one or two at a time at the dealer. Compared to buying one at a time, Viton in bulk is still a bargain. Even at 3-4 times the price of Buna-N. But if there is no need for Viton over Buna-N that's what I'll buy.
Excellent. Rather than buying in bulk, just mail order or go to your local hydraulic shop and buy the kits you need. Probably a lot less expensive than you ever thought.
/ O-Ring material #12
Viton or Buna-N? Which is better for hydraulics? Viton costs more, is it worth it? Planning on stocking up on ORFS and ORB O-Rings.
Buna-N, 90-durometer definetly for ORFS & ORB......:thumbsup:
If it's used in a static seal (staionary ) use 90 duro
if it's used in a dynamic seal (moving) use 70 duro
Viton not important as the only advantage would be in a high-temp environment or odd chemical resistance....
/ O-Ring material #13
Also buying in bulk is not a great idea cuz orings have a definet shelf-life (5 years or so)
Oring kits are the best option for everyday usage....then refill from your local supplier that has fresh ones on-hand....
/ O-Ring material #14
I have a drawer full of new o-rings about 15-20 years old I think and they are mostly worthless.
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
KJ K3325 33'x25' Barn Shed (A60463)
KJ K3325 33'x25'...
