Offset Box Blade?
   / Offset Box Blade? #1
PioneerMan
I need to grade my drive. There are trees on the sides, so I am thinking that unless some major trimming is conducted, my tractor will scrape the trees. It is a cab unit, I am actually more worried about the tractor than the trees. Is there an offset box blade, or should I get an offset blade? Suggestions?
Tractor is a 4320 cut, and thinking about a 4 or 5 foot blade. I 'only' have to go about 1500 feet so I don't mind doing two passes.
   / Offset Box Blade? #2
At some point in time the trees will have to be cut back. May as well do it now. Something I've learned in life "don't let trees dictate". I can show you a few things on my property where the previous owner did just that and it can make it plenty aggravating at times.
   / Offset Box Blade? #4
Never seen or heard of an offset box blade. I think that you should be looking at either a 7' or 8' rear blade. JD rates the 4320 to use up to an 8' rear blade. Forget about the 4 or 5 foot blade. Waaaaaaaay to small for your tractor. I think that a good 7 or 8 footer with skid shoes would work best for you, other people may feel differently.
Just my :2cents:
   / Offset Box Blade? #5
This is solid advise. And the sooner you cut them the easier it will be.
   / Offset Box Blade?
Alright sounds good. I will start cutting. Thanks guys.
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2013 MACK CXU (A50854)
