Oil blows out overflow on Kubota B5200
   / Oil blows out overflow on Kubota B5200 #21
G'day do you have a worn bush or shaft in the front of the pump? If you do then you could allow pump pressure onto the back of the seal and they are not designed to take all that, check the seal when you remove the pump and see if it has turned inside out, this will indicate excess pressure you may be able to get a local hyd shop to rebuild it cheaper than new. Also may not hurt to check relief pressure too. Good luck
Jon
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
2022 BOBCAT T770 SKID STEER (A60429)
2022 BOBCAT T770...
Wolverine Quick Attach Screening Bucket (A59814)
Wolverine Quick...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
