oil change pump
   / oil change pump #11
I tried a pump from Northern, paid like 40 bucks plus ship, total pc of junk.
Try using a pipe wrench, it will work, then buy a new drain plug. /forums/images/graemlins/grin.gif
   / oil change pump #12
Make sure you use a pair of curved jaw Vise-Grips. Clamp them on and use another pair to tighten the adjusting knob. The jaws will bite in very hard and will not slip. I replaced my adjusting knobs on a couple of pairs with bolts so I could use a wrench. Do not tighten too much or you will crack the head of the Vise-Grips.
   / oil change pump #13
Thanks for the info Phil.
   / oil change pump #14
Just did a quick google on the Pela 650 (model I have)...
Yachtsee Boat Gadgets $59.00
Jerry B. Leach Co. $59.00
If faced with replacing my Pela 650, I would have a difficult time deciding between another 650 or the new PRO 14...
   / oil change pump
Bingo! and a tip of the hat to Bigbear. A 14" pipe wrench did the trick and a new drain plug is now installed.
Won't need the Gator now, but think I will try one of the pumps for other vehicles and implements.
2018 Genie 2632 26ft Electric Scissor Lift (A50322)
2018 Genie 2632...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2020 FREIGHTLINER M2 26FT BOX TRUCK (A52141)
2020 FREIGHTLINER...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
Kubota B7200 (A50120)
