oil change pump
   / oil change pump #11
I tried a pump from Northern, paid like 40 bucks plus ship, total pc of junk.
Try using a pipe wrench, it will work, then buy a new drain plug. /forums/images/graemlins/grin.gif
   / oil change pump #12
Make sure you use a pair of curved jaw Vise-Grips. Clamp them on and use another pair to tighten the adjusting knob. The jaws will bite in very hard and will not slip. I replaced my adjusting knobs on a couple of pairs with bolts so I could use a wrench. Do not tighten too much or you will crack the head of the Vise-Grips.
   / oil change pump #13
Thanks for the info Phil.
   / oil change pump #14
Just did a quick google on the Pela 650 (model I have)...
Yachtsee Boat Gadgets $59.00
Jerry B. Leach Co. $59.00
If faced with replacing my Pela 650, I would have a difficult time deciding between another 650 or the new PRO 14...
   / oil change pump
Bingo! and a tip of the hat to Bigbear. A 14" pipe wrench did the trick and a new drain plug is now installed.
Won't need the Gator now, but think I will try one of the pumps for other vehicles and implements.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
1995 CATERPILLAR 621E (A52472)
1995 CATERPILLAR...
2013 TOYOTA TUNDRA (A52472)
2013 TOYOTA TUNDRA...
2012 John Deere 7280R MFWD Tractor (A53472)
2012 John Deere...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
BESTWAY AG VSK50 LOT NUMBER 105 (A53084)
BESTWAY AG VSK50...
