oil change pump
   / oil change pump #11
I tried a pump from Northern, paid like 40 bucks plus ship, total pc of junk.
Try using a pipe wrench, it will work, then buy a new drain plug. /forums/images/graemlins/grin.gif
   / oil change pump #12
Make sure you use a pair of curved jaw Vise-Grips. Clamp them on and use another pair to tighten the adjusting knob. The jaws will bite in very hard and will not slip. I replaced my adjusting knobs on a couple of pairs with bolts so I could use a wrench. Do not tighten too much or you will crack the head of the Vise-Grips.
   / oil change pump #13
Thanks for the info Phil.
   / oil change pump #14
Just did a quick google on the Pela 650 (model I have)...
Yachtsee Boat Gadgets $59.00
Jerry B. Leach Co. $59.00
If faced with replacing my Pela 650, I would have a difficult time deciding between another 650 or the new PRO 14...
   / oil change pump
Bingo! and a tip of the hat to Bigbear. A 14" pipe wrench did the trick and a new drain plug is now installed.
Won't need the Gator now, but think I will try one of the pumps for other vehicles and implements.
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
2017 Polaris 500 Ranger Diesel Utility Cart (A50322)
2017 Polaris 500...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
Bobcat 443 Skidloader (RUNS) (A50774)
Bobcat 443...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
