Oil Filter Question
   / Oil Filter Question #11
I think that if you change your oil and filter regularly, that the Purolator or any name brand equivalent to the one that you found by Purolator would be an acceptable cross reference. The tractor is too new, and there are not very many of them in the field, so Purolator and the other manufacturers have not had a reason to do a cross reference to it. If you send the old filter to Purolator, they could dissemble it and tell you the cross reference. At that point, they might even start a listing in next years books, but don't bet on it. It all depends on who opens the package and to what degree that he cares....
   / Oil Filter Question #12
Out of curiosity, how much does the dealer want for a filter?
I shopped around town and bought an after market filter for my kubota for 9 bucks. Next time I was at the dealer (100 miles away) I bought kubota part for 6.50. Are you really saving anything buy shopping for an aftermarket filter?
I'm not looking to save money with an aftermarket filter. I am looking for a better filter. Purolator, Pureone filters, as well as Baldwin filters are very high quality filters. They also have an anti-drainback valve that prevents old, dirty oil from draining back into the engine after the engine is turned off since the filter on my tractor is mounted horizontally.
   / Oil Filter Question #14
Baldwin oil Filters for my Bx22 are around $6.50 each.
   / Oil Filter Question #15
Mike,
You do have the D905-E engine I assume.
So what is the filter number You use?
   / Oil Filter Question #16
B179 and yes the old D905E
   / Oil Filter Question #17
There are several filters that are comonly used on the small diesel engines. The afformentioned Baldiwn B179, B1400, B1402 and others all share similar characteristics with some dimensional changes, and bypass pressure setting.
   / Oil Filter Question #18
If you want the fine filtration of the Pure One then I would use it. The automotive application that it was designed for would likely require more oil flow than a low RPM engine like a tractor, so flow won't be a problem. With your Diesel you may need to change the filter more often, not sure. But it looks like you've done your homework on the match up. The ones that come to mind are the motorcraft FL1A and FL-400s filters that can be cross referenced to Pure One. I believe these too would fit your application. I would put the largest filter on that would fit since the cost isn't any more. I've been running a pure 1 FL-400s eqivalent on my Onan for years now. The oil stays a lot cleaner than the stock onan filter and it's half the cost.
I don't think you'll have any problems with the filters you want to put on. Go for it, let us know if you observe any differences.
   / Oil Filter Question #19
Mike,
Is the Baldwin filter for $6.50 better than the OE Kubota filter Available at Emerichs or Mail order for $4.50-$5.00???
I didn't cut the one open that I took off last august during my 50 hr service. Guess I should have.
Unless I see different I'm going to stay with the OE filter, for less $.
   / Oil Filter Question #20
</font><font color="blue" class="small">( Mike,
Unless I see different I'm going to stay with the OE filter, for less $. )</font>
Last time when I saw Jim his oil filters were more then $5. I think online has the OEM filters for around $4.65
Info I found online.
KUBOTA Oil Filter
M20 X 1.5 thread X 3" OD X 3-1/8" HT
8 to 11 PSI pressure relief
Anti drain valve, 27 micron rating
Baldwin Oil filter
Anti-Drainback Valve
8 PSI By-Pass Valve
M20 x 1.5
OD: 3”
Length: 2 27/32 (72.2)
22 micron rating
Beta ratio’s are still unknown for both.
2001 New Holland EC215 Hydraulic Excavator (A52377)
2001 New Holland...
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A54757)
UNUSED WOLVERINE...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2012 Dodge Ram 5500 Chipper Truck (A52377)
2012 Dodge Ram...
