Oil recommendations for DK45S
   / Oil recommendations for DK45S #1
fetchtx
Kioti DK45S
Changing and would like recommendations front axle- particular for heat in tx
   / Oil recommendations for DK45S #2
It's the same system, any quality multi-purpose tractor hydraulic/transmission fluid.
   / Oil recommendations for DK45S #3
This is a tough call…. My dealer said i should stick with 90 weight gear oil instead of transmission oil. Said it will prevent seal leak better.
I never know whos more correct.
   / Oil recommendations for DK45S #4
With the original post edited to be the front axle my answer will change,
for the front axle I use a synthetic multi-grade gear lube.
For the hydraulics and transmission as original request it remains a quality multi purpose fluid.
   / Oil recommendations for DK45S #5
I have used Valvoline 70W90 synthetic in the front axle since the 50 hour service. Use Rotella T 15W40 in the engine and use Rotella HD tractor and transmission fluid in the tranny hydraulic system. The Rotella transmission fluid is repacked Donax TD or Spirax S4 TXM which is the Kioti recommended fluid.
   / Oil recommendations for DK45S #6
Gee, this is the exact same thing im using. I currently hace 1650 hours on mine. Just did the service last week. Washed and waxed the tractor also. Still looks new
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2008 Ford Ambulance (A47477)
2008 Ford...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2015 Ford Focus (A51694)
2015 Ford Focus...
