Oil viscosity change for a 5.7 Hemi?
   / Oil viscosity change for a 5.7 Hemi? #41
OK, to put it in a tractor content. With mechanical pressure gauges on tractors and trucks I have seen oil pressure on the gauge before they started while cranking.
Sure, but that same pressure is there if it fires up quickly, or you continue cranking it.
That’s also only pressure in the bottom end. If you’re upper end..valve stems, overhead cams, etc, are “dry” , they’re dry either way.
Then there’s wrist pins and such, that require minimum motion speed for correct lubrication.
   / Oil viscosity change for a 5.7 Hemi? #42
Yeah, turning just the oil pump is one thing . That’s totally different than cranking an entire engine assembly with compression strokes using a starter motor.
I think people confuse the two.
I'm definitely not confusing the two.
Thankfully my batteries as good enough to turn the engines fast enough to build pressure. Not that I can monitor it on the gauges while cranking, but on the 3.6 V6s it's easy enough to hear the difference when starting them. They're noticeably quieter after having primed them.
Besides, while the starter works against the compression, the oil doesn't have to deal with the forces of actual combustion. Many Challenger owners use the starter method, but who knows, we may all be wrong by not letting a supercharged engine fire instantly (which they do) and go directly to high idle, at well over 1,000 rpm.
   / Oil viscosity change for a 5.7 Hemi? #43
Wow. So oil pressure isn't equalized in the engine, but stays pressurized only in the bottom end until the engine starts??
   / Oil viscosity change for a 5.7 Hemi? #44
I didn’t know we were were talking about supercharged engines. Guess I missed that part.
The forces on the components to spin an engine at a given rpm , are closely the same, be it the crank driving the rod, or the rod driving the crank.
No free lunch here
   / Oil viscosity change for a 5.7 Hemi? #45
That’s right. Oil to valve stems is not pressurized, and requires a minimum oil flow , and turbulence across the head, from the valve train
2009 Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
2009 Kubota...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
2011 Kubota KX080-3 Midi Excavator (A53421)
2011 Kubota...
2023 RAM 3500 4DR 4X4 CAB AND CHASSIS (A56138)
2023 RAM 3500 4DR...
