Oil vs propane heat
   / Oil vs propane heat #71
I myself have a wood stove, and most of the heat is used heating the house.. a wood fireplace does waste a lot of heat. If you can believe the specs it’s 80% efficient. Not bad for wood. Our old unit was less than 50 %
only way you can come out heating with wood.
A fire place also burns a lot of wood in addition to sucking all the heat out.
Just think about people in the old days that had no choice but to burn wood, only to lose all the heat that was being generated day in and day out !
   / Oil vs propane heat #72
I heated with wood for over 40 years, about 20 face cords annually, never really minded the labor involved. I figure it gave me all the exercise I'd ever need. My place includes 20 acres of hardwoods and I think that by selectively cutting there is more timber at the end of the year than before. My wood furnace is ducted into the oil burners' ductwork so we have good heat distribution throughout. My options besides wood were oil or propane. While I never costed out propane I could tell from experience that it might take 1,000 gallons of oil annually. But I got tired of seeing the chiropractor so I went geothermal.
I still make 4 or 5 cords annually for the fireplace and for those days when it's -10 and windy. This old farmhouse was built to the exacting building codes of the 1830s, so despite a lot of remedial insulation it can need a lot of BTUs on nasty days.
The geothermal cost an obscene amount of money initially but has paid for itself and now pays dividends to me. A bonus is hot water and central air with what I consider a minimal increase in the electric bill to run the associated pumps and blowers.
   / Oil vs propane heat #73
Unless you have some type of wood burning insert, You are not saving by heating with wood.
That chimney is like a giant vacuum and any heat that is generated by burning wood, is sucked right back up that chimney along with other heat in the home
I agree with the chimney draft. That heat going out isn't what we're after. We're after the radiant heat created in the process.
I was heating a 2200 sq ft shop with a wood stove I made. It easily heated that shop. If you weren't careful you'd have it so hot in there you couldn't work. :)
   / Oil vs propane heat #74
There are some wood burning stoves that have been in existence for hundred’s of years that are very good at heating a house.
[video]https://en.wikipedia.org/wiki/Masonry_heater[/video]
Many of the European settlers to North America would build this type of stove using material available locally. Fireplaces were not the norm for these settlers.
   / Oil vs propane heat #75
Like I said, the only way to come out efficiently heating with wood is with a stove, insert ,etc,. When I was a young lad. we would visit friends that lived out in the country. All they had for heat was a fire place. I never saw one with a stove ,or insert. I suspect these wood stoves, inserts were too expensive for them to purchase
   / Oil vs propane heat #76
I have installed a wood stove in my big fireplace. We haven’t used the small one in my office to date. This is my third house I’ve done and I agree on the heat savings vs a fireplace.
However, this house has Rumford fireplaces. (You’ll have to google it) and to my surprise the big one did throw a lot of heat into the living room. I have a granddaughter that is little and I installed the wood stove behind a screen anyway for safety.
The stove with blower has been the best wood heat I’ve found to date.
Currently gathering up the parts to install one to the latest safety standards in my detached garage. Er... I mean my shop. Some codes and insurance says you can’t have wood heat in a garage but it’s fine in a “shop”.
Oops. How’s that for thread creep. <laughing>. Sorry bout that.
Well, my wife and I actually went to the house we are planning on buying today, and as usual, the real estate listing was wrong. The house is oil, forced air heat, but in the sun room, there's a fake wood burning stove powered by propane. So it's just supplemental heat in one room which is powered by propane. So, the house is heated basically by oil heat. Thanks for all of the oil vs propane heat advise, but it turns out I don't have to make that choice anyway.
   / Oil vs propane heat #78
^^ I do not recall ever hearing of a house with those three - - oil, propane and electric tank/services.
   / Oil vs propane heat #79
That is what we had when we moved in. It’s now wood replaces propane. Still three systems. Quite common around here.
   / Oil vs propane heat #80
We have all 3. Baseboard heat by oil, Propane as a fireplace that has a blower for heat and electric baseboard in the lower level.
Caterpillar 259B Compact Track Loader Skid Steer (A51691)
Caterpillar 259B...
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
New Holland Hay Rake (A51573)
New Holland Hay...
