Old Ferguson Plow ID
/ Old Ferguson Plow ID #1
vegaome
New Martinsville, WV
1970 MF-135 and 1951 Ford 8N
Howdy Folks,
A friend gave me a two bottom plow. He said its a 14 inch two bottom. The model part of the tag is damaged. I can make out Ferguson, the serial number and AO-4 is all I can read on the model part.
Did ferguson make an AO-4 two bottom plow?
I will try to take some pictures later.
v/r
Mike
/ Old Ferguson Plow ID #3
I have a Ferguson 2 bottom that looks like those in the pics. Bought it for 32.00 at an auction. Didn't need it, but I have it just in case while the price was right.
Here are the pictures. I dont have a plow manual to look up parts. Just trying to figure out what model it is and hopeing someone out there has one.
v/r
Mike
/ Old Ferguson Plow ID #5
You can look up parts manuals online at AGCO Parts Books. You don't need an ID, just click on the View Books link next to "Guest User". I tried finding parts for an old plow a friend bought at auction, but most of the cast parts were no longer available, unfortunately.
Howdy,
Thank you all for the replies.
Boone, there are a couple that are similar.
6011Artist, does your plow have a plate with the model number?
GreenWannabe, I looked through the manuals but could not find it.
All, have a happy Easter.
v/r
Mike
/ Old Ferguson Plow ID #7
vega, after reading your post again and you asking for numbers I went out and looked at mine and got numbers. I googled and learned mine is a 12" plow. It is complete except the two coulter wheels and arms are missing. The rear furrow wheel is there. The numbers on mine read: Type 12-AO-28, No: 40567
I learned it was a match for a TO-20 Ferguson tractor....probably Fergusons match for the 9N Ford as far as tractors. I had doubts/questions as to was it the right plow for my TO-35 and conclude yes, it will work fine. The 35 has a little more power than the 20.
After looking at your plow and the parts breakdown I found online, I see yours is complete except for the "cross shaft", correct name for the part by the diagram. Also it showed "check chains" on the diagram but you'll probably get away with not having them. They may have even been eliminated on your model as I looked and saw no evidence of yours having them removed.
My question to anyone having experience with these plows. Are the coulter wheels a must? What are their purpose other than making a cut in the grass making turning the dirt precise and easy? Can I get away with not having them and what will be the result? Also, what is it worth missing the coulters? I'll probably never use it. Would like to know the value in case someone wants it more than I do.
/ Old Ferguson Plow ID #8
Manuals Forum - Expanded Thread Page
vega, here is a link to the sight I got my info off of. It has manual pages downloaded and some good reading for a person not knowing a lot about them. Hope this helps.
It talked about how to adjust the cross shaft that you are missing. If you need me to measure the horizontal distance of the shaft in my clamps I'd be glad to do that for you. It says to never change that measurement but change the twisting degrees to get what you need.
Maybe this will be of help and feel free to ask me if I can help in any way.
Howdy 6011Artist,
I do have the cross shaft, its in the bed of the truck. Its been welded but I think it will hold. The coulters are froze up and one is tore up some. I have a spare that may fit. Also one of the shares is bent some. I plan on taking them off and trying it out.
Thanks for looking and for the link.
v/r
Mike
/ Old Ferguson Plow ID #10
It looks a lot like the MF-62 plow I have, which is a 12-2. I have a Ferguson plow manual that I found online which explains set-up pretty well. Aside from not having trip beams and spare parts being like hen's teeth, these are very good plows.
The coulters do a better job if your sod is thick and tough, makes for a much cleaner job.
Here's a short video of it in action. The field hadn't been plowed in over 20 years, so the sod was pretty thick and difficult to turn cleanly. A little higher ground speed would have been good, and a slightly shallower cut would have helped too.
Chilly plowing garden - YouTube
Sean
Howdy Sean,
I do think they are similar. You have a good looking set up there. Thank you for sharing. Have a good evening.
v/r
Mike
Howdy Folks,
Sorry to trouble you but I was wondering what color to paint this plow. Anyone know what the original colors were? Thank you and have a good evening.
v/r
Mike
Howdy Folks,
I took one of the shares off and took it to tractor supply today. I could not find a match but had him order one that has the same bolt pattern. I will probably have to modify it to fit. The share on this plow has three bolts spaced about 5 and 1/4 inches apart. I also think it may have been red originally. I did try and to straighten out the ID plate some more and I believe its an AO-14 plow modle. Have a good day.
v/r
Mike
/ Old Ferguson Plow ID #14
Howdy Folks,
v/r
Mike
The Ferguson plows were Machinery Gray. The same as the 9N and 2N tractor colors. The Dearborn plows were red.
I have a Ferguson 12-AO=28 and when I took the plow shares off I found the gray. Rusteoleum has a machinery gray
which is pretty close. The red may have been a replacement part. The plow share points are hard to find if not now extinct...for the 12 in. plows.
Tom
Howdy Tom,
Thank you for responding. Actually I thank everyone for responding and sharing information. Its been a big help so far. I really want to fix this plow. It is 14 inches between the beems. I freed up the coulters today but the spare one I have is still stuck. That is the disk bearing is frozen. I have it soaking tonight and wil try to free tomorow. I am missing one disc scraper. I hope I can get it fixed. Have a good evening.
v/r
Mike
Howdy Folks,
Not sure if this will help anyone or not but I looked at the numbers on the back of my plow shares and they are 475 134 M1. I called a local dealer and they told me its a good number. I ordered two. Now I do not know if these are the original shares or have been modified. So I'm working a couple of options for shares, one from TSC and one from a Massy dealer. I will let you know how it turns out.
v/r
Mike
/ Old Ferguson Plow ID #17
Howdy Folks,
Mike
The 12" and the shares for the 14 and 16" shares are different. The 2 larger shares are available. the 12" is a one piece share and like i mentioned, hard to find if any...
Tom
Howdy Tom,
I'm kind of new at this, but I see what your saying. I wish I knew the part numbers for the different type of shares that are avalible. I will just be happy to get some new ones no matter the type. Thank you for the information. Have a good evening.
v/r
Mike
/ Old Ferguson Plow ID #19
Tractor Supply lists them on page 182 of their 2013 catalog. Moldboards, shins and shares. They will be listed as
Ford parts. they can get the 14 and 16" items...
I see you just down the river from me. I am by the Ohio, Pa and WV intersection where the Ohio River leaves PA...About 6 mi. from
that point.
Good Luck..
Tom
Thank you again Tom for the info. We are pretty close then. I'm about an hour south of Wheeling and only a couple miles from the Ohio river as the crow flies. I also see you have a 1614 power king. I have one too and they are good little tractors. Have a good evening.
v/r
Mike
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
UNUSED RAYTREE RMVR76-76" HYD VIBRATORY ROLLER (A60432)
UNUSED RAYTREE...
iDrive TDS-2010H...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
