Put another way: I would absolutely, positively, under no circumstances whatsoever, feel comfortable with my $20,000 machine in a rented trailer with a capacity of 2,500#. No way, no how. Just too small.
I'll second that!
*How do you unload the trailer with the tractor.?I just re-did someones driveway for them yesterday. I dropped the tractor off, un-chaining it in about 3 minutes, went to the quarry and picked up 3 tons of stone, unloaded and spread the 3 tons of stone in about 20 minutes, then spent 30 minutes dressing the driveway with the box blade, then loaded the tractor, properly chaining it down in under 5 minutes. The whole thing, including picking up the stone, took about 2 hours. *If I wasn't able to unload the stone with my tractor, I'd spend 2 backbreaking hours just getting the stone off the trailer.
I don't know how Keithinspace does it, but I remove the rear gate, approach the trailer from the rear, backdrag the material off onto the ground until I have a "ramp" that lets me drive the tractor up on the trailer. Then I just grab it and go! Repair the "ramp" as necessary until the trailer is empty. Pull the trailer forward, pick the material up from the ground and I'm done.*How do you unload the trailer with the tractor.?
This is one way I unload my 6'X12' trailer.How do you unload the trailer with the tractor.?
That's one wayI don't know how Keithinspace does it, but *I remove the rear gate, approach the trailer from the rear, backdrag the material off onto the ground until I have a "ramp" that lets me drive the tractor up on the trailer. Then I just grab it and go! Repair the "ramp" as necessary until the trailer is empty. Pull the trailer forward, pick the material up from the ground and I'm done.
Yup, something like that. When I had the 'cheesegrater' rear gate (on my previous 5' x 10' trailer), I had to fortify it with some angle and 2 x 12's or my tractor wheels would just punch right through. Even then, I was not successful unloading it with my machine. I don't recall why...perhaps I just didn't like how it pulled up on the ball every time (no support legs on the ramp like on my big trailer) and worried that something was going to fail catastrophically. Always seems to with me. Don't know why.This is one way I unload my 6'X12' trailer.
~~~~~~ ~ ~ ~Yup, something like that. When I had the 'cheesegrater' rear gate (on my previous 5' x 10' trailer), I had to fortify it with some angle and 2 x 12's or my tractor wheels would just punch right through. Even then, I was not successful unloading it with my machine. I don't recall why...perhaps
1*I just didn't like how it pulled up on the ball every time (no support legs on the ramp like on my big trailer) and worried that something was going to fail catastrophically.
With the dovetail, my problem is that the deck is quite a bit higher than Mr. Volfandt's trailer. The fold-down ramps are too steep and the rear implement drags on the ground (BH or box blade). So I have two "approach ramps" out of 2 x 12's that I carry around with the trailer. They get me up in the air a little so I can 'make the turn' without dragging anything on the ground. It ends up working pretty well. I just climb up in there and scoop away.
I have it down to where I can sneak in at a bit of an angle and even scoop everything in the corners along the way and just leave myself with a small scoop at the front of the trailer.
Someday I'll get some high-capacity aluminum ramps to replace my wood approach ramps. They'd look nicer, anyway.
2*And the wood is a little heavy.
3* I have two "approach ramps" out of 2 x 12's that I carry around with the trailer.
Understand completely, one must be confident in their eqt, as I am with mine....1*If the trailer would happen to come off the ball it wouldn't be very nice.
Can't load from side with forks.keith, any pics of the trailer? i am wondering how everyone fills the trailer. I am guessing some have made side walls out of plywood. Are there any disadvantages to a trailer with non removable walls?
That was a significant factor in my purchase and subsequent modifications. Similarly, you can't really OFF-LOAD with straps from the side since the lifting height of a BX FEL is limited. I have a 500# outdoor fireplace on my trailer right now that was loaded by forklift and will be off-loaded with my FEL, so it does happen...what I wouldn't give for a set of BXpanded bucket forks right about now...Can't load from side with forks.
I'm considering the addition of a winch to the front of the trailer. Then I can side-load a pallat in the back and pull them toward the front.[/QUOTE said:Now there's a thought!![]()
A trailer isn't a trailer without a winch is it?Now there's a thought!![]()
I towed my machine, FEL and BH installed, on my 3,500# 5' x 10' trailer twice. I found that given the dimensions of the machine, I could only balance the tongue weight if I backed the machine on. I had rails, so the BH bucket didn't go over and there was no benefit to manipulating it over the rail since that would have, again, sent too much weight to the ball. I just swung the BH boom all the way to the side and had the FEL bucket sitting on top of the cheesegrater rear gate....you could back in on the trailer and have BH over the A frame in front...
