One of those days. Long
   / One of those days. Long #1
Berniep
Platinum Member
Greensburg IN
2005 BX23
It started out very nice. Good weather and all.
I thought I would trim some branches off Some trees to make it easier to mow under. About halfway through I decide to cut a sapling close to the ground and hit a rock. This is my last good chain because Lowes had the wrong chain in the box the last time i bought a spare so for the next half hour I am almost burning through the rest of the limbs. Well I get all that cleaned up and even cut behind the house with the rotary cutter. I get lunch and decide to head for under the power lines which haven't been cut yet this year. About a third of a mile from the shop (this is pertinant to the story) I cut for about an hour and at some point I look back and the R/C looks funny. One of the wheel assemblies has come out. It is the orange king kutter with two caster wheels that are held in by set screw type bolts. Well after driving around for looking for a little bit I find it and head back to the shop. Got them cross drilled and bolted, now they ain"t comin out. Now I hit a lucky streak of almost two hours of mowing without incident.
It's kinda hilly and I am getting used to leaning a little but I am on a relatively flat portion and I think to myself "why is the tractor still leaning?"
I look at the low side and sure enough the right rear is extremely low. I got it to the entrance to the field but thats as far as I wanted to go. If the bead came unseated then I would have to take it off in the field and i didn't want that as there were some storm clouds on the horizon. So it's off walking to the shop for the portable air tank. I could have hopped on the 4wheeler and brought it back but I figure that I will just have to walk back to get the 4weeler eventually anyway so I will just carry it. It takes most of the tank to get it aired up and as soon as I start to drive it it starts hissing and leaking back out. So I end up having to make two more trips to the shop to fill the air tank to get the tractor back to the shop. I get a patch put on it with surprisingly little drama. I was able to wedge a piece of wood in and get to the damage without unseating the lower bead so I didn't lose all the slime I have in the tire. I am starting to feel good about my day again. Well I have about two hours of mowing left (easy mowing on relatively flat ground as I had already done the hard stuff) and about two and a half of daylight so I decide to head back out. made less than one round and I hear a loud hiss and something hits me on the leg. It is slime being blown out of a hole in the left rear tire this time. I immediately put it in high, shut of the pto and head for the shop. After a couple of revolutions the slime starts to do its stuff and I think I might make it back to the shop when I notice the tractor is not steering right. Sur enought the front tire is very low and the sky all of a sudden looks very black. I think "screw it I am driving it back, if I ruin the rim or tire then I can buy a new set of R4s that won't get a flat from driving over a blackberry bush."
I made it almost all the way back before the front bead came unseated and was able to drop the R/C and get it in the shop with no apparent damage to the tire or rim. I put a jack stand under the left side frame to keep from resting on the rims overnight and proceeded to crack open a beer and hit the porch swing for the last hour of daylight.
Here is a pic of the poor thing.
Hopefully tomorrow will be better.
   / One of those days. Long #2
Bernie, I have days like that also, but I generaly end up with a mashed finger too before I call it quits.
ron
   / One of those days. Long #3
I say good planning.............. having a couple cold ones ready in the fridge ! :D
   / One of those days. Long #4
3 flats in one day??
Congrats. You just tied my personal best. :D
   / One of those days. Long #5
Berniep,
Must be the phase of the moon! I had one of those days too. Final clean up pass on a pit for some irrigation valves. Concentration lapsed a moment as I begin planning the piping run in my head. Stop, stop, stop! There's a wa- pppsssttt-ter main there!
The only consolation is it was a beautiful day for a motorcycle ride to the hardware store to get an oops fitting.
Thanks guys.
The really agravating thing is I have been all over this field and had not any problems. Eventually I want to reclaim this area for hay but at this rate I will have to put steel wheels on the bx to get it done.
   / One of those days. Long #7
I ripped out about 1500 sq. ft. of multiflora roses today and am thinking I better run out to the garage and see if the tires are still full after hearing your story.
This week, in order, I lost and presumably buried a pair of sunglasses that fell off my hat at some point, bruised but didn't break two different fingers working with some boulders and lost the nut off the bolt that holds the seat on my BX24. All in all I'll take my week over your day of 3 flats.
Thanks for the story and pic!
   / One of those days. Long #8
I can't really top that. But I did get a flat front tire the first 15 minutes I owned my BX24.
All I did was drive it through my lawn. I had picked up a thorne from some brushed I had hauled acrossed the lawn with my 4-wheeler.
From that point I wasn't real sure I was going to like my tractor.
I got the tire fixed yesterday and went back out and punctured the left rear again:mad:. It is small bushes that were cut by the people the utility company has to clear under the power lines. When they are green I can drive over them but I guess since they are drier now they puncture the tires. Anyway I made it back to the barn and there it sits all gimpy. I am stopping in at the dealer to get a set of r4s on order for it. I am hoping that they help. It's really not going to go over well if I come home next weekend and say I gotta have them foam filled:confused:.
Now watch them be higher than the price he quoted me this spring because of some world wide rubber shortage or something:eek:.
   / One of those days. Long #10
What kind of tires do you have on there now? They kind of look like R4's to me:confused:
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
10222 (A56858)
10222 (A56858)
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
