Only runs with key in start position
   / Only runs with key in start position #1
bigDOJ
Mitsubishi 180 D
Was running good, then started dying often, and now will only run when the key is in start position. Any Ideas??
   / Only runs with key in start position #2
Weak "hold" position on fuel solenoid?
   / Only runs with key in start position #3
Check your grounding.
   / Only runs with key in start position #4
If the starter turns over and the engine fires the fuel solenoid is as grounded as can be.
I suggest there's a faulty ignition switch from wear or corrosion.
btw, starter solenoids have pull and hold coils but few other do. The fuel solenoid is so much smaller and requires far less current to hold it. It likely doesn't use a relay either.
The fuel solenoid may be more like a diverter valve solenoid that draws a few amps vs a starter that takes nearly all a battery has.
   / Only runs with key in start position #5
That is not always correct, the starter uses a different ground path than the rest of the system.
   / Only runs with key in start position #6
The starter and fuel solenoid are grounded through the engine block. If they both work in the key start position they are grounded ok. Neither has a ground wire/connection to fail except the main ground to the engine. (wouldn't crank over)
A bad key switch might not send power to the solenoid in the run position I've replaced two ign switches and problems ceased. One was in '98 and one was in a '04. Both had spent plenty of time parked outdoors, but I suspect contact wear due to age & hours.
My original thought was a faulty key switch, that I replaced, after determining that it was not a fuel problem. The new switch did not solve the problem. Do you think it could be a bad solenoid or something else?? I am not very educated on these mechanical issues, so all of your help (in laymen's terms) is deeply appreciated. Thank you very much
   / Only runs with key in start position #10
I had a similar problem on a borrowed B21.
Naturally I was far from my shop.
Could start and move as long as I left key in start.
OK, did that enough to clear the road and did trouble shooting.
After poking around I discovered a blown 40 amp fuse.
Naturally no spares so I pried it open and forced the fusable wire to make contact.
WORKED so I limped home., bought and installed new fuse.
Why is it troubles always show up when far away and no tools.
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
2005 John Deere 7320 (A60462)
2005 John Deere...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
