Only runs with key in start position
   / Only runs with key in start position #11
Has it been verified that he even has a fuel shutoff solenoid?
The plunger on the fuel solenoid stays open all the time, even when the key is in off position. After I start engine, it closes. If I unhook one of the wires connected to that solenoid, the tractor will stay running all the time. I have to put the key in start position again, before it will die. Does that mean I need a new fuel solenoid???? Or can I bypass the solenoid somehow? or is it OK to run the tractor like that?
   / Only runs with key in start position #13
Sounds like a relay issue to me.
   / Only runs with key in start position #14
If the key is on and the gauges work I suggest running with the one wire disconnected if it will. It could lead to a stuck relay. I'd connect it & check it for ground or voltage with the engine off and the key in each position. Having a schematic could aid in diagnosing with a quick look but I suspect the wiring layout isn't too complicated.
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
