Bob, those pictures are very telling, but I submit that they are deceptive. The fact that the loader arms on one are curved is but one of the factors that increase visibility on that tractor, two others I see being that the hood slopes considerably lower on the blue tractor and that the loader arms seem much closer together. Those three things (sloping hood, close loader arms, curved loader arms that follow the slope of the hood) all work together as a system to increase visibility. If you were to put the blue loader on the kubota, you wouldn't get significantly better visibility since the hood is still high in the front. Conversely, if you put the kubota's loader on the blue tractor you wouldn't lose much visibility since you would still be able to see down the hood. It seems to me like there's a couple different areas in which visibility can be added by design, center, left and right. Center is determined first by hood height and slope, and secondly by loader crossbar location. Left and right visibility, which for the purposes of discussion will be the area between the edge of the hood and the edge of the bucket, are determined by loader arm design and placement in the space between the hood and the loader edge. If a tractor and loader are designed together for visibility, then both areas of visibility can be improved.
whodat
Edit: another area I couldn't determine well enough to speak of is seat height. What, if any, is the seat height difference between the two tractors? The higher the seat, the higher your vantage point, and the better your downward viewing angle. Please note that i'm not saying that curved loader arms don't provide more view, I'm simply saying that your direct comparison between the two tractors shows the advances in ergonomics as a package much better than it shows the advantage of one loader design over the other.
