PA160 STH unboxing!
   / PA160 STH unboxing! #41
my challenge as someone totally new to this is not having any frame of reference, other than having some
general knowledge of what a weld should look like. Hmmm, seems to be spattering a lot. Me? the rod? the
temp setting? At this point, will always assume it's me... ten degree angle? check. Right temp? check...
I'll save the HF rods for July 4th. Some kid would have a long day getting one of them to light...:D
   / PA160 STH unboxing! #42
If you want to have fun on 4th of July, you need one of these with 200-PSI of air behind it. :laughing:
   / PA160 STH unboxing! #43
are you doing a little air arc gauging there shield arc?
   / PA160 STH unboxing! #44
me too. The 140 that i got won't run 6011. Still want to get a dual voltage inverter that will run 6011 properly.
If I were you I would not make a statement like that. Every welder under the sun can weld with the appropriate size and settings with 6011. Some weldors on the other hand cannot strike an arc or run a bead.
6010 is a different issue.
A neighbor expressed an interest in welding, so we spent about an hour today showing him how to strike an arc and run a bead. I started him on 3/32" E7014, but I thought the larger, more visible puddle of a 1/8" rod might be a little easier for him to see, so we moved up to some 1/8" E6011 and 7018. Before too long, he was laying down beads pretty decent. Even that first hour made a big difference between sticking the rod a bunch and him just firing right up. We ended up doing several overlapping passes on a butt joint and a fillet joint for a closer.
We got the 7014 dialed in at just the right heat level so the slag was popping off on its own in one piece! Nice to know that, with this digital welder, I can just turn the dial back to that number if I need to. With my old welder, I would have been afraid to touch the output lever because I'd know I'd never get it back just right in that spot.
All told, we burned maybe a pound of rod, so I'd say the little 160 STH has been put through its paces. The arc force control made it much easier to teach him to maintain arc gap, since it was relatively safe to have him drive the rod into the puddle without having to worry about extinguishing the arc. I'm still getting a feel for how this welder runs a little differently than my old one, but it's coming together. The 7018 we ran was just beautiful.
This weekend, I'll be going to an informal welding workshop, where I plan to hook the 160 STH up to a borrowed argon tank and try out the TIG features. I'm going to swing by my LWS and pick up some tungsten and some filler rods some time this week.
   / PA160 STH unboxing! #49
All machines have there little querks. My little maxstar HATES 6010 and will snuff out like blowing a match out all day long, but all in all
a very awsome machine whenever I have to go super portable.
   / PA160 STH unboxing! #50
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=311215"/>
Agree with 6010 issue on small inverters like the Maxstar 150 or Everlast 140/160 but no machine that size should have trouble with 6011, 6013, 7014, 7018 etc. even the little 80amp HF inverter does well with those rods in 3/32.
I went to a small welding workshop/get-together today, and one of the guys who came brought a bunch of aluminum drops from his work, and let everybody spend, literally like five hours playing on his machine while he looked over their shoulder and gave them tips. It was pretty sweet! From somebody who's never really TIG welded at all straight to aluminum on my first day? Man, I'm still grinning.
I hoped to get my 160 hooked up to a borrowed argon tank and try it out some today, but no luck. I'm missing the barb fitting on my regulator that will connect it up to the welder. One of the guys there had a hose with a thread on one end and a barb on the other, but it was leaky. I struck the first arc and immediately toasted my tungsten. Shielding gas is not optional, you know? C'est la vie...
   / PA160 STH unboxing! #52
pretty exciting without argon isn't it? Since my setup is a 17V torch I have forgotten to turn on the argon a couple of times.. You know it right away:shocked:
James K0UA
I got some quotes for an argon cylinder the other day. I don't remember the exact numbers, but Airgas only sold up to 80 cf cylinders, for something like $190, or a 5 year lease for $220. I was surprised that the lease price was basically the same as the purchase price, and was due up front, so kind of... what's the point of the lease, you know? Praxair was cheaper and sold both 80 and 150 cf. I don't remember the exact prices.
I know that the bigger a cylinder you get, the cheaper the refills are. Is 150 too big to put on a rolling welder cart? It seems like mostly everywhere I see selling for personal use (like on eBay or whatever) is 80 cf or smaller.
   / PA160 STH unboxing! #55
Mine is 125, and 150 would be easily doable.
I did some work with my nemesis, E6011, tonight. In order to maximize my chances of success, I did careful joint prep, including beveling and *gasp* even cleaning a spot for the ground clamp. I had been having trouble running 6011 with my new welder--having to maintain very tight arc length to keep the arc from going out, for example--but that all seems to have been related to poor grounding. With my new work table, I get a little lazy with just setting items on the tabletop and counting on contact to provide a ground.
(EDIT TO ADD: Now that I think of it, these were 1/8" Blackstone rods, and the ones I had previously been having trouble with were 3/32" Hobart rods, but I still think poor grounding was the problem and not the rods.)
Joint prepped and tacked.
It's 3/8" bar, ground to perhaps about a 1/8" land on a double-bevel. I would have done a smaller land if I wasn't running out of daylight and wanting to get some welding in before nightfall.
The first thing I did was try to dial in the best output. This is Blackstone 1/8" E6011. The box calls for between 80-120 amps, so I started at 100 and worked towards success.
At 100 amps, there was plenty of penetration. The bead profile was flat in the bevel. The rod ran a little too fast for me to keep up with it, however, and I had problems with undercutting.
90 amps. Less undercutting. The rod was still a little too fast for me, as can be seen in my uneven and too-fast travel speed. It seemed like it was burning in so fast that I had to go fast to keep up with it, although this may not have actually been the case.
85 amps. Now we're getting somewhere. Very little undercut and almost no slag at the toes. This may have been the best 6011 bead I'd ever run.
Still 85 amps. Trying for a more consistent travel speed and an explicit wet-in of the toes on the "pause" part of the whip-and-pause.
85 amps felt pretty good, but I figured I'd better go for 80 just to see what it was like. It felt too cold, although it ran okay. The bead was taller and it wasn't significantly easier to run than at 85. I suspect this one has less penetration.
The backside shows that none of the beads burned totally through the 1/8" land, not even the 100 amp one. Apparently, I wasn't as close to burning through as I imagined on those hotter passes. I never did see a keyhole. The reason I kept moving was because the bead was cratering out the toes and sinking into the bevel--although, now that I think about it, that's supposed to happen if you're going to do a cover pass next. Maybe this was just more bevel than I should have tried to fill with a single run of 1/8" rod.
Finally, I flipped the bar over and did another four beads on the back side bevel. These two were the best of them. Again, I really tried to focus on pushing the puddle back into the crater and watching it wash out to the toes of the weld. I think I did okay compared to my previous efforts in my short career as a hobby weldor.
As always, feedback is welcome!
   / PA160 STH unboxing! #57
You know those 80, and 85-amps welds don't look that bad.
If you're shooting for open root? Cut down on the thickness of the land, and open up the gap. When welding open root, you want all the sparks on the inside / backside, and you shouldn't see much of the light from the arc. If the gap closes up on you, point the rod in the direction you're traveling, and open up the arc length. If you're burning through, point the rod back into the metal already deposited, and shove the rod in tight, (close up the arc length).
What land and gap would you suggest, assuming a 1/8" rod?
Do you think it'd be reasonable to try to fill a 1/8" deep bevel with a single pass of 1/8" E6011? Generally, I would say that the bead height should be less than the size of the rod, but in a bevel, I'm not sure.
One other question: Is 6011 slag supposed to be a real PITA to clean off? I always hear people talk about how 7018 has heavy slag and 6011 has light slag, but at least with 7018, it all chips off in a few pieces. It seems like with 6011, unless I break out the wire wheel, it's impossible to get the slag off the bead. I'm just pecking and tapping at it with the hammer forever, picking out every little bit. I think one reason I have such a bad impression of my 6011 beads is that I am often looking at them through a patina of slag. Once I get a wire wheel on them, they pretty up a little.
   / PA160 STH unboxing! #60
Josh, two words - "needle gun"... :=) Steve
gps trailers (A56859)
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
