sd455dan
Elite Member
- Joined
- Oct 23, 2012
- Messages
- 4,831
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
I have a a problem with the JK going dead in a few days if I don't keep it on a battery tender or run it. It has a LOT of electrical accessories - CB,Winch, 5 sets of lights, subs, touchscreen, air compressor, etc. Well I disconnected EVERYTHING aftermarket and still have the draw. Went through the factory fuse box 1 fuse/relay at a time with the meter between the neg. cable and the Neg terminal of the battery to monitor the draw. Stayed the same after pulling each individual fuse, one at a time.
Now I am baffled - I thought as I pulled a fuse, checked the meter I would see a drop in the draw at some point, and then know that is the circuit to chase. Didn't work - anyone have any suggestions on what I am missing?
THANKS
From left field...
Ran into a similar problem on a RAM truck, battery would go dead in a few days.
Every fuse and relay removed except the key off battery fuse.
Turned out the Horn button had shorted out years earlier. owner had removed the Horn fuse which would make you think problem solved.
nope.
The gauge cluster has a CPU in it that when things are working normally sends out check signals to the radio and Horn button after the vehicle is turned off. If no closed switch or draw is detected the computer goes into sleep mode , this reduces current draw to `~10milli amps.
Since the truck I worked on was detecting a horn button pushed, the signal the cluster CPU would never go into sleep mode. This resulted in a .5 to 1.5 amp continuous draw. Replacing the Horn button / airbag fixed the problem. It can also be disconnected at the actual button. The radio can do the same thing if it has a problem- basically the Cluster CPU detects a draw and then won't go into sleep mode.
FCA electrical architecture.:confused2:
Not sure if the JEEP uses the same type of system but i wouldn't doubt it also being FCA .
truck was a 2004 , model JK started production in 2006 ?
edit
As was posted earlier a bad alternator can have a draw thru the Alternator if an output diode is damaged.
When you said EVERY fuse has been pulled did that include the IOD (Ignition Off Draw) fuse?
also when doing a current leakage test needs to wait about 3 minutes to give the computer time to go into sleep mode if IOD fuse is still in circuit.
hope this helps , Good luck, electrical problems can be a hair puller.
