Patio Project
   / Patio Project
And one final picture for now. This is the moment of truth, the concrete truck arrives. That's Mrs. S and myself doing the grunt work. Put down 7 1/2 yards between the circle and the patio footers. Very hot, humid day so we all had a dip in the kids pool afterwards /forums/images/graemlins/grin.gif
Progress will now slow considerably. I'm going to start laying block this weekend up to grade, then brick above grade. This is the part I've never done before so I may not be too quick to post all my "experiences". Tips & hints encouraged /forums/images/graemlins/smile.gif
   / Patio Project #12
</font><font color="blue" class="small">( That's Mrs. S and myself doing the grunt work. )</font>
Who took the picture?? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
The cement truck driver? Hope he didn't charge you for working outside of his union! /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
   / Patio Project
<font color="blue">Who took the picture </font>
#1 son was assigned the digital camera and #2 had a disposable. Gotta give them something or they'd have been waist deep in concrete. They both had the assignment of taking a cold "PowerAde" out to the driver while he was washing out (with instructions to stay out of his way).
The driver was most helpful. He hopped out at one point and manned a shovel along with us /forums/images/graemlins/smile.gif
   / Patio Project #14
The picture of the pool is scary, ours looks just like it. My octogon pad is a little smaller diameter though.
I'm a surveyor and I can't think of a good way to layout a full circle without having the radius point or some pretty high grade survey equipment. There might be some ways to do it if its just a portion of a circle and you had the distance between the end points. You could build a batter board over the stake that would be over the dirt piles and use a plumb bob to mark the center on that. You could then tie a string on the nail & use a plumb bob to mark points on the footers, but make sure to pull your string fairly level.
   / Patio Project
It's been a while but work on the patio has progressed. Several things I've learned along the way including the notion that I do not enjoy masonry work as much as most other home improvement work I get into. That also explains the lack of photos along the way. It just hasn't been that fun for me.
This picture is laying the first course of block on the footer, down in the trench. It's not difficult work but it does wear you out. Hoping the brick work is a bit easier on the person /forums/images/graemlins/smile.gif
   / Patio Project
This is your basic work area shot. For some reason my mortar tub is missing. I used all premix mortar and mixed it one bag at a time in a tub. Between the mixing and lugging the blocks I wasn't very fast /forums/images/graemlins/smile.gif
   / Patio Project
Now fast forward a couple of months and about five skids of block. The patio sub-structure is complete. I filled it with about 10 yards of recycled concrete all tamped in. We've been using it but still need to get a concrete cap poured this season yet. Just today we decided to go with tile instead of brick for the paving material so I need to add a couple more inches of fill.
There will be a brick pilaster at each intersection with wrought iron railing in between. Stairs coming down toward the yard you can see in the picture.
I've decided to hire out the concrete flat work and put off the face brick until next spring /forums/images/graemlins/smile.gif
   / Patio Project
This project has really been a two-for-one. At the same time I've been working on a raised circle in the front drive. This picture shows the block work done, again waiting for face brick. Yesterday I rented a trencher and ran electic from the house to the circle so we can run a fountain pump and/or lights if we choose /forums/images/graemlins/smile.gif
   / Patio Project #19
I like it.
I like it enough to understand that you should feel guilty about having so much fun so close to home.
Seriously, ninety percent of the fun is getting there. But in your case I'd guess it's more like ninety five because it's obvious you're savoring each step of the way.
I really like that.
   / Patio Project #20
</font><font color="blue" class="small">( It's not difficult work but it does wear you out. )</font>
It may not be "difficult" to learn how to do it, but it's sure hard work. /forums/images/graemlins/frown.gif It's looking good, though.
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2005 Cheverolet 2500 Pick Up Truck (A59814)
2005 Cheverolet...
