Robert,Pretty good guess though
As ultra cool as the Mog's are, that Zamboni was pretty cool too. How do take care of the ice rink without it?
Since I got the front snow blower for the Kubota, I just use that. Since the blower has down pressure, I just sharpen the edge and it will scrape the ice down some. I just use the 1" ID hose to flood the rink, takes about 45 min. to put about 1/4" of water on it. The problem with the Zamboni, was its weight. At close to 8k lbs. when filled it was just too heavy and would crack the ice is the ground was not completely frozen under the ice. So with a mild winter like we are having now, I could not even use it. The B2710 with cab and blower weighs in at about 2500-3000 lbs. So you can see the difference right there. It still will crack the ice sometimes, but not as bad with the wide turf tires. Plus the ice does not have to be as thick to support the weight.
