Pick up cab clearance lights - required?
   / Pick up cab clearance lights - required? #31
Mine came with my 08 2500 single wheel GMC. LED. One single side one failed under warranty. A hundred Bucks! The same one failed out of warranty! I don't like the old looking FORD ones, but a hundred bucks? I bought the wrong side one off E-Bay cheap, and cut it apart to work on the other side!
$100 fix is crazy for a $65 option. If you build your own, that's what the upcharge is for the lights with pretty much all 3 trucks. $65.
   / Pick up cab clearance lights - required? #32
$100.oo fix for what should be a 79 cent bulb is the modern way!
Paying a dealer to replace the assembly could make the cost a lot higher still!
   / Pick up cab clearance lights - required? #33
I knew 1 person years ago that had them on a 10+ year old truck, his leaked.
Do they all leak eventually?
I am not sure.
Mine was a 2000 and they leaked, I ended up siliconing around the bases AND the lense. No more leaks. A couple years later, I had a bulb burn out, replaced it and didn't reseal with silicon and it leaked between the orange globe and the black base until I sealed again. I actually pulled the headliner down and saw the water dripping in from the cab light.
   / Pick up cab clearance lights - required? #34
It was always said that vehicles with AC were prone to corrosion across the top of the windshield. So, I guess having holes there does not help.
2015 MACK CXU TRI-AXLE DUMP TRUCK (A58018)
2015 MACK CXU...
2010 New Holland TD5050 95HP 4WD Agricultural Tractor w/ Bush Hog 2610 10ft. Rotary Mower Attachm... (A55973)
2010 New Holland...
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
Auger Drill Bit (A56857)
Auger Drill Bit...
PALLET OF MISC PARTS & SUPPLIES (A58374)
PALLET OF MISC...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
