Picking a trailer for new JD 5083E
   / Picking a trailer for new JD 5083E #1
bglz42
DIckinson, Texas!
2013 John Deere 5083E
I'm looking for a trailer for my 5083E with 553 loader. I will occasionally haul with a mower attached so I'm looking at 24' gooseneck minimum. What are the pros/cons of lowboy vs deck-over?
I figure the deck-over might be advantageous if I were hauling something wide like a 7' to 8' mower?
   / Picking a trailer for new JD 5083E #2
DECK OVER, and absolutely a GN, My tractor (5083E) with the 563NSL, loaded tires and base weight of the tractor (granted im usually hauling something else) pretty much maxes out my GN, I pretty much sold my 1 ton Cummins because it was hairy stopping it in a hurry. I would reccomend a Low Profile Deckover, some manufacturer's make them some dont. Moritz does and its a full 3" lower to the ground. (not advertising them, just what i personally own.) If you start trying to get the correct tongue weight on your truck, your going to run out of deck in a hurry, Hence why I usually ended up with a very pin heavy trailer and hence why I upgraded to a bigger truck. Hope that helps!
btw, IIRC loader figures in around 1500-1700lbs, and I believe beet juice adds almost 800 (780 if you wanna be technical, 16.9-30) per rear tire. so we are easily talking 7435(per deere)base tractor plus extras, which rounds out to about 11k, Any additional attachments are extra of course. I usually happen to have a 2k counter weight with me. So I'm right at my trailer max.
Thanks, RedNeckRacin! That was exactly the type of info I was searching for!
   / Picking a trailer for new JD 5083E #4
I am very interested in this topic also. Anyone have any pics of hauling around there 5083e? or 93 or 101 for that matter, they are exactly the same size if i recall.
I am leaning toward a tandem gooseneck 20 plus 5 dovetail...
   / Picking a trailer for new JD 5083E #6
I got a 20 plus 4 dovetail gooseneck that I haul my 5085M w/ H260 loader around on. This setup is a bit heavier than a 5083E w/ 553 loader, but size is about the same I think.
It fits fine without a rear implement, but with something on the back, the bucket needs to go up on the gooseneck itself for sure.
Here is just the tractor on the trailer:
I have hauled this combo before with no issues (sorry, no pic of it loaded on the trailer), although it is real right getting the ramps up. A 5' dovetail or another few feet of deck length would have been nice, but I'm having a hard enough time turning around in tight places as it is with my crew cab long bed truck, so I'm happy with what I got.
Thanks SO much for the pics! Thats what I needed to see...
   / Picking a trailer for new JD 5083E #8
My 1 ton SRW cummins and the brand new 5083E. 563NSL, loaded wheels, and a little bit of a pucker factor! I think a dually would help immensely with the weight.
   / Picking a trailer for new JD 5083E #9
Thanks for the pics!
   / Picking a trailer for new JD 5083E #10
Sorry not a deere, but it's about the same size tractor. The Gn is a 22ft plus 4ft beaver tail
2014 UTILITY 53X102 DRY VAN TRAILER (A45677)
2014 UTILITY...
2005 Cummins DGBB 43.7 kVA 3-Phase Diesel Generator (A46683)
2005 Cummins DGBB...
2016 Ford Focus SE Sedan (A44572)
2016 Ford Focus SE...
2019 Bobcat E32i Excavator (A46683)
2019 Bobcat E32i...
2017 Ditch Witch Trencher (A46683)
2017 Ditch Witch...
2007 John Deere 9570 STS Combine  Premium Cab  FarmTRAX Yield & Moisture  1,846 Sep Hours (A46878)
2007 John Deere...
