Pictures from a skid steer mowing contractor
   / Pictures from a skid steer mowing contractor #521
You have no idea. We had clean fence lines and field edges. I quit/left the farm in 2006 and gradually returned to taking back all the ground from 2014-2018. By the time I had returned fences were grown up field edges had creeped in because nobody cares anymore. Have spent years working on getting everything back to where they belong. There are places I am missing 18-27' of field edge because they have grown in. Have removed all the brush from fence lines taken the loader and pulled in years of plowed out dirt that people kept rolling into the fences/brush. It doesn't take long when you don't care. But it is alot to bring it back. I have several more years of work left to do. Once caught up it's easy, until then...............
I will try to remember this post and post pictures when I have time.
Also, fences are good places for birds to rest and poop weed and briar and pook weed seeds; so fence row automatically has more large weed pressure than open field. Even missing 6 or 8 months of maintenance; your dealing with 8+ feet of nastiness (thick and tall, but not woody); and that's when people look at it and say F it.
Absolutely LOVE the work you do mowing with the skid steer. I could look at the before and after photos for hours...Christ, this thread is 52 pages so I have been.
I'm glad you like it, I will try to keep posting some before and after photos along and along.
   / Pictures from a skid steer mowing contractor #524
I am considering a flail. How did your flail do compared to a rotary cutter?
I thought it left a much nicer finish than any of my rough cut bush hogs leave and the customer yesterday commented on how much better it looked than when cut before, and he doesn't know a thing about tractors and mowers. I do believe it can probably get expensive when you have to replace the blades, on this mower their are 42 sets of blades but they can be flipped and used to cut on both sides and appear to be heavy duty.
   / Pictures from a skid steer mowing contractor #526
Do you spray the fence line with chemicals? I'm still building my fence, but it's slow going. Areas that I have cleared, and built the fence are now starting to grow back. I've mowed and sprayed roundup on the fence, but it doesn't last. I tried another product that is supposed to keep the ground clear, but it doesn't work either. I think that I need to find something stronger. It's such a waste of money buying chemicals that don't do anything.
   / Pictures from a skid steer mowing contractor #527
Eddie, you can try a section using Pramitol. Not sure what the chemical name is but I know there is a generic for it that I get at Ag South/Supply. It doesn't last forever but being a ground sterilization product it does last quite a bit longer than Roundup. I mix it with Roundup and 2,4D.
I don't generally spray anything other than weed and vine killer in fence rows, I have on two different occasions seen a whole tree line of massive oak trees killed by people practicing with chemicals that they didn't know anything about and spraying it in the drip line of those big trees.
   / Pictures from a skid steer mowing contractor #530
Did you pick that up at Weeks June auction? I saw a pretty new JD flail at the auction, and saved it; but didn't bid.
Edit: wrong picture, I must have nor screen shot the flail, only the tiller
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A52576)
2019 FREIGHTLINER...
53ft trailer Vin IUY VS2532 7M0152 01 VS2RA (A51694)
53ft trailer Vin...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
53ft refer trailer (A51694)
53ft refer trailer...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
