Just got this Warn plow on my 2012 Rhino yesterday, bought the plow back in 2014, finally got it on, a 16 hr process with iffy instructions, but least all the nuts bolts were in the box, they just weren't labeled to tell which bolt goes where. After a small test yesterday found that the plow is tripping a little on the easy side, so I did some more adjusting today, now I need to try it again see if I made any difference.
I also put these diamond shape tire chains on, they grip better than I thought they would. I also ordered some regular cross tire chains for front just incase.
If things work out I'll be able to give my tractor a rest
<<<<After 2 hrs of taking all the nuts and bolts out and getting this plow in the more vertical upright angel, made a small polw test and the plow tripped to easy I thought, so 1 hr more of repositioning the plow back to original scoop angel mode, thing do go faster after doing the fit up a couple times, but tirison at the same time.
<<<A picture of some of the nuts and bolts.
(This the angle the plow was when I first hooked it up, thought it was laying back to much in scoop mode, so I straighten up like in the first picture, but then the plow tripped on the easy-ish side>>>
