y
Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,021
Last year was the first year for the Toolcat. I ran the rear blade on the back and the SnowSport plow on the front. The SS plow floats which works good on the FEL and it has the rubber blade so I can go across the grass. I have not tried the 3pt blower on the back yet as I would need 3ft+ to motivate me to install it. Being able to plow in both directions made quick work of my areas.
   / Pictures of your snow weapons #5,022
2 years on this one so far. Retired county plow welded to a Bobcat QD plate with power angle. I do the county road from the farm to the pavement, about a mile.... Going to put on front chains this winter. Steering can be an issue when the drifts get a couple feet high....
   / Pictures of your snow weapons #5,023
Always thought those Toolcats were a interesting piece of equipment, neighbor down the road from me has one thinks it’s a 2005.
Jim.
   / Pictures of your snow weapons #5,024
Looks like here in a few months from now. If the side of the ditches don’t get cut low enough that’s what our road can look like.
   / Pictures of your snow weapons #5,025
To address the steering issue, some people make the plow float independent of the loader arms so the loader weight stays on the front tires.
   / Pictures of your snow weapons #5,026
Probably not a bad idea but in as much as I bought the plow ready built for 800 bucks and ran the bags out of it for the last 2 years, I believe front chains will do it. Tractor weighs almost 10K with the plow on. Sure is nice to plow with heat and stereo. For really tough going I have a Lucknow rear mount 86" blower too. Haven't needed it for a while though.
NWS says this winter will be abnormal snowfall and cold temps. Typical Michigan winter. I'll be snuggled up in front of the wood stove with my wife and dog. No more going to work, retired.
   / Pictures of your snow weapons #5,027
I finally moved this pic to my computer, last winter, second year with the plow. It sure moves the snow!
   / Pictures of your snow weapons #5,029
Looks like your ready for anything old man winter might throw at you. :thumbsup:
   / Pictures of your snow weapons #5,030
I think you will find front chains help a lot. On my set up I can keep the FEL weight on the front tires and float just the plow like on a truck or if I want to cut hard pack I can float the FEL and add it's weight to the plow by dumping the SSQA plate a little forward. Most times the chains will hold the steering when I do that but not always.
gg
   / Pictures of your snow weapons #5,031
I push with a hydrostatic 3038e, 6ft snow pusher. Set the rubber blade 3/8" above the shoes and it catches no gravel, dream to use.
No problem on stock R4's running 16 psi in the rears, and 750lbs 3pt Ballast.
You do any corners with that? I have two parking lots, and two driveways, and some other areas...95% of it is straight on, but there are two curves I'm worried about. Would prefer a push to a plow on the front in most scenarios.
   / Pictures of your snow weapons #5,032
Traded a Kubota L4240 towards a Kubota M7060. Trygg chains on the rear and grip studs on the front tires (2 per lug). Stepped up from a HLA 2000 7'6" plow to a HLA 3000 9' plow. Used to use a box blade or snowblower for additional counter balance. Have on order a Landpride RTB4596 rear blade for weight and to improve snow removal/snowbank set back. The base weight of the tractor is about 2000lbs more. Also the cab will be handy in the winter. There is a chance that it won't snow now.
Here is a pic of the tractor with plow (the hydraulics are hooked up since it is just being moved from one spot to another on the property):
   / Pictures of your snow weapons #5,033
Very nice!
Where abouts in Vermont are you?
Bethel here...
   / Pictures of your snow weapons #5,034
I use a Land Pride SS1596 plow on the FEL of my L6060 with a Fressori cinder spreader on the 3 pt. I use cleated chains on the front only which gives me all the traction I need. On steep slopes I sometimes lift the FEL a bit to put more weight on the front tires giving the chains more bite.
For the deep stuff, I remove the spreader and put on the Woods SS74 blower.
   / Pictures of your snow weapons #5,035
View attachment 620914 View attachment 620915 View attachment 620916
How do you like the LP plow
   / Pictures of your snow weapons #5,036
I've used it 2 seasons so far and I like the way it performs. It seems more stable than the old Woods I used before.
The only complaint I have is the cheap orange plastic edge marker rods. They are too brittle and break easily. They are also $60 a set to replace. After breaking the second one, I switched to the much cheaper Western markers which are coated steel and much more flexible.
   / Pictures of your snow weapons #5,037
Sounds like an easy upgrade, thanks for the input!
   / Pictures of your snow weapons #5,038
I need the markers on my plow truck, but I can see the ssqa tractor plow very well from the cab.
   / Pictures of your snow weapons #5,039
Nothing beats a push going straight to a stockpile.
Corners you have to do a series of angled straight passes, or hover the push so its shoes are just off the ground to follow a contour.
That is also with a deere 3 family tractor, if i had a 4 family tractor i am pretty sure it would do contours without hovering.
If you mean corner, like in front of a garage door, its easy. You tip the push fully forward and it has a second rubber edge. I can clean right tight to anything.
Extremely happy with the push. Express Steel makes a very sturdy productive unit.
Reduced my fuel bill and time down over half vs a snow bucket on the 3acres I keep clear in winter.
2018 CSY (A59231)
2018 CSY (A59231)
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
