Plasma cutting - how much air do I really need?
   / Plasma cutting - how much air do I really need? #41
I have the Powermax30 and I can cut 1/2 steel with good results. Thats way over what it's rated for.
Agreed. I have the Powermax 30 as well and I love the small size and portability. It has done everything I have asked of it, and the 110VAC input makes it easy to take to another location.
For air I run a pair of small, ancient Kellogg compressors that I picked up cheap on Craigslist. Running both of them simultaneously makes up for the low CFM of each. The pumps are cast iron so I expect them to outlive me.
   / Plasma cutting - how much air do I really need? #42
I just kinda smirk to myself everytime I read one of these threads where someone wants to spend several hundred $$$ for a plasma rig because they cant make a decent cut with any oxy acetylene torch or think its cheaper because they dont have to buy gases. Danger of storing compressed gas bottles is less than storing a plastic gasoline container so any fear there is only perceived and not real although just as in storing any flammable product proper precautions should be followed. Please post back your costs for equipment, parts replacement ie tips, nozzles, tungsten electrodes etc, larger air compressor and quality of cut that you get using you new plasma rig compared to what it would have cost you to get your oxy rig upgraded.
If you already have a cutting torch and are only going to be using Carbon Steel, then your money would be better spent in learning how to use the torch you have and investing in some larger bottles and a bottle cart to move them with.
   / Plasma cutting - how much air do I really need? #43
Or maybe he just wants one. It's his money!
   / Plasma cutting - how much air do I really need? #44
The rating for a Powermax45 (Hypertherm) is 6 cfm@ 90 psi. The plasma system has an internal pressure switch that will shut down the DC power when the inlet air pressure drops down to about 80 psi. Most compressors cycle from 90 to 120 psi......some as high as 150 or 160 psi. So....with a compressor with a flow (cfm) rating lower than the plasma- will allow you to cut until the compressor cannot maintain the minimum inlet pressure. Depending on the tank size on your compressor you will likely get 20 to 40 seconds of cut time.....then you will have to wait for the compressor to build pressure...then start cutting again. I have used my Powermax45 outside of my shop many times on a small 3.8cfm@90 psi Porter cable compressor (for nail guns, typically). I can get about 30 seconds of cut....which usually is adequate for small jobs...and if it is sheet metal I am cutting....I can cut a couple of hundred inches in 30 seconds.
The big problem with to small of a compressor is that it will run all the time, and will get very hot....as well as add a lot of moisture to the air. Compressors that are not designed for continous duty simply will not last very long. For field or hobby use....a smaller compressor is often adequate. For shop use and or production use....the compressor should be double the requirement (so a Powermax45 should have a compressor with 12 cfm@90 psi flow).....for best results.
A Hypertherm Powermax30 uses about 4.5cfm @90 psi.
Jim Colt Hypertherm
I have never owned a Plasma cutter but I plan to get one for home use. How much air flow do I really need? My compressor is a 2.5HP 10 Gal Harbor Freight jobbie. The sticker "says" 5.2 CFM @ 90 PSI. I use it to blow up tires, run some air tools like an impact wrench, air ratchet, etc. It works okay but obviously if I have a lot of bolts to hammer out I will run out of air after a few and have to wait a bit for it to build up.
I have need to occasionally cut anything from sheet metal to 1/2" mild steel. While 95% of the use would be 3/8" and thinner it seems prudent to spend a little extra and get a machine with some extra AMPs that easily handles what I want plus a little. Of course with extra AMPs seems to come additional air flow requirements.
I'm currently looking at something like the Miller 625, Hobart 700i, or Hypertherm PM45. The Miller wants 6 CFM, the Hobart 4.8 CFM, and the Hypertherm 6 CFM.
Is it feasible to run these from my air compressor? Is there an easy way to measure the actual CFM of my compressor?
I really need to stay with a portable type compressor. I don't have room for a larger 220V model.
I appreciate any suggestions from anyone with more experience on these cutters.
   / Plasma cutting - how much air do I really need? #45
A horsepower is equal to about 750 watts......since compressors have a lot of friction....lets say closer to 800 watts are actually consumed. A 20 amp 120 volt outlet can provide about 2400 watts......so in reality, under perfect conditions a 3HP electric motor will run on a 20 amp 120 volt circuit.....as long as there was nothing ellse running on it.
Compressor manufactures use a locked rotor rating to advertise horsepower....which is totally useless....but many will buy based on what the spec sheet says. I have seen 6 HP advertised on 120 volt compressors.
Jim Colt
Somebody correct me if I'm wrong, but I was under the impression it was realistically impossible to get more than about 2 HP out of a typical 120v outlet. No? HP and cfm ratings on those little compressors are optimistic.
I have basically the exact same compressor, but with an 8 gallon tank, and only a "2 HP" motor (air-quotes intentional). It is rated at 4.5 cfm at 90 PSI and I have measured it at about 4.2 cfm. If you want to estimate the actual cfm of your compressor, you can follow these steps. They're not the most accurate, but they will get you in the ballpark.
   / Plasma cutting - how much air do I really need? #46
This may have been true with the first hand held plasma's from 30 years ago.....but today you plug the plasma into an outlet, plug in an air hose, lay the torch right on the plate....pull the trigger. You can guide the torch on a template or straightedge (metal, cardboard, plastic, wood). It takes just a few minutes to get used to the speed. Todays hand plasma's are pretty easy.
Jim Colt
You realize it takes just as much skill with a plasma as it does oxygen & acetylene to get a good cut?
   / Plasma cutting - how much air do I really need? #47
I tried the dragging technique, but some plates are just too rough to get a good cut, so I use a burning bar, or the CNC table when I can. But sometimes you just have to free hand things.
Guilty as charged! Do not confuse want with need. :) I'm just a home user. I don't have a farm and I don't have a shop. Right now the torch kit lives in the shed with the lawn mower which makes it next to impossible to use when the weather turns cold and I cringe when the temps are near 100. The plasma can live in the basement with everything else. I don't like using the torch. I've never had any formal training and the only thing I can remember is "A before O or UP you GO". heh
I have a wire welder but only weld 2-3 times a year. Mostly repairs and an occasional fabrication. In most cases I need to cut material first.
Like most home tinkerers / DIYers, for what I have in tools and gadgets I could cover paying someone else to do the work for the next 20 years but it wouldn't be near as much fun or satisfying.
For the amount of usage per month I don't think the cost of consumables would be an issue.
I really appreciate all the input I've gotten here. It has been very helpful. I'm still not sure when I am going to get one. Still need to look around and do my homework.
   / Plasma cutting - how much air do I really need? #49
When I got my plasma cutter I looked all over the net for reviews - the Hypertherm PM45 was the ONLY one in that size range that I could find ZERO negative comments about, other than price (around $1600) - it's rated for 1/2", but I've seen videos (soon to be verified personally) of cuts over 1". I have a large (21 CFM, 80 gal., 5 REAL horsepower (Baldor motor, 25 amps @ 240 volt) compressor, so it's not starved :=) - I set up a manifold just for that, with a spare outlet in case I want to run another tool. Since this compressor puts out 165 psi, my manifold consists (in order) of a regulator (so I don't blow anything), then this Amazon.com: Astro Pneumatic 2618 Air Control Unit, 120cfm Capacity: Home Improvement as a pre-filter, then this Amazon.com: Motor Guard M-100-KIT 1/2 NPT Clean Air Filter Kit: Home Improvement -
So far, I've only put maybe 10 hours on it total, with NO sign of wear on consumables. As previously mentioned, practice is everything. A cutting guide also helps make you look like you know what you're doing, and weren't "CUI" (cutting under the influence)
The PM45 is made here in the US - the Cutmaster 42 is NOT. Last I checked, the Cutmaster 52 and up were still made here.
Check out several videos of cuts made with the 45 here
Powermax45 handheld plasma cutter | Hypertherm
Bottom line - no buyer's remorse here... Steve
I thought I posted this earlier. I have a PM-45 at home. Works Great, Consumables last good all though you pay the price for that. I use the 45 for a lot of various cutting on all metals. But...If you pull the cover of of yours you will see at least 4 countries of origin on internal parts. Funny how some are from China......USA made?? kind of. Just syain..
   / Plasma cutting - how much air do I really need? #50
Jim Colt
You can buy or make a little chariot for you cutting torch also so you can just drag (actually roll) it along, use straight edges also, but with any equipment, you need some skill to use it for good cuts and long use of the equipment. Dragging the tip on the metal will mess up the tip if a bit of spark or molten metal pops up on to it requireing expensive replacement parts.
   / Plasma cutting - how much air do I really need? #51
And TBN folks are just the ones to help him spend it whether WISELY or not is yet to be determined.
   / Plasma cutting - how much air do I really need? #52
I have had a plasma CNC machine since 2005. I got it as a hobby, but its ended up being used more times than i can remember to make a bracket here, repair this item there, etc.
I can make a quick drawing in Coral, transfer it to a cut path drawing on the computer in my shop and have the part cut in nothing flat.
Last summer i added a hydraulic down assist to my post hole digger, and needed a simple attachment point for the ram. Took about 10 minutes on computer then sent it to the plasma table. A few minutes later the part is sitting there ready for a light sanding and welding to digger bar.
Im so spoiled now, i really dont care what this hobby cost me 7 years ago. id do it again in a heartbeat.
I live 45 minutes from town, and i HATE having to drive there to get a part i can make myself.
   / Plasma cutting - how much air do I really need? #53
i am just finishing up with yet another 5 year contract on my torches, and it will be the last one because i've gone to a plasma cutter. i will still have the portable torches and tank setup i've had for the last two decades, but for any cutting done in my shop, i will be using a plasma cutter. my current tanks are a 118cf acetylene and 250cf oxygen, and the last time i checked, it was over $100 to fill both. if i go through 2 tanks of each a year, that's $200. around here, bottle contracts are $35-$50 per year per bottle, so there's another $350-$500 for 5 years. tanks never run out at the same time, so every year that's four round trips to exchange tanks - $12.50 fuel per trip, give or take, plus all that wasted time. just that is $1600-$1750 over the next 5 years, which is pretty much what i just paid for my hypertherm 45. in the first 5 years i'm breaking even, and i'm thinking that i should make at least 10 years before the cutter fails. the cost for gases over the next 5 years will be the same, or likely more, based on inflation. what i spend on electricity and consumables will be far less than the second 5 year contract. i figure i'm break even somewhere around year 6 or 7, and past that i've saved money. sure, it's more up front, but that's also because i bought a more expensive machine. buy a cheaper one and your 5 year contract and first fill will not be much less than the cost of a plasma cutter.
the tips shipped now are called "drag" tips for that exact reason - that's what they are designed and intended for.
i haven't used mine other than one quick test - other things taking priority right now, but i can say that the cut is far better than a torch. i made one cut with a straightedge and i didn't take any care in paying attention to travel speed or anything. when finished i was left with the slag/dross along one edge. i smacked it with a hammer and it fell off to reveal a clean sharp edge. i have spent two decades with a torch and i can make pretty decent cuts when i need to, but i can make better cuts with the plasma on day one. i can guarantee that i will be saving money and time on grinding.
another plus for me is that i won't have to spend any of my off time getting tanks. i'm decades from retirement, so when i need to get a tank filled, it has to be in the tiny window of their business hours and my off hours, generally saturday morning. that limits my evening time that i can do anything if i have to wait until saturday to get tanks swapped.
   / Plasma cutting - how much air do I really need? #54
People have ways of justifying things when they WANT them and don't NEED them. I'm in that boat just not as much as i was in the past.
Don't saying you don't NEED the plasma; you may very well need it. I've had the money saved up for over a year now for a plasma (Hypertherm 45 or Miller 625) but cannot get past the fact that I really don't NEED a plasma cutter. Although it would be awesome to have if needed.
I can take a 5-10 minute drive to my local welding shop and have the CNC laser cut parts for $75/hour. How many hours cutting can I get for the price of a good plasma? At least 24hrs...
Not nearly as practical than having my own 24hr/day accessible means to slaughter conductive materials!
I will probably buy one soon as I really WANT one lol
   / Plasma cutting - how much air do I really need? #55
Do NOT buy the Hobart 110 unit with compressor if you want to cut anything other than sheet metal! I made the mistake of buying one because it said it could cut 1/4", at the time I thought that was all I would be wanting to cut. I tried it on a piece of 1/4" x 2" flat bar and it barely made it through it. I knew immediately that this wasn't the machine for me. I took it back to the retailer where I bought it and got a refund, went to the welding supply store and bought the Hypertherm Powermax 30 and couldn't be happier. I run mine on 110 (only because mine didn't come with the adapter cord they have now) and I routinely cut 3/8" x 6" flat stock and use it all the time. Now my biggest problem is scraping up the money for a bigger Powermax! I want a 60, don't need it, just want it! LOL
Happy cutting :)
   / Plasma cutting - how much air do I really need? #56
The only ones of these I have heard of run off of 110v and are therefore limited in the thickness of metal they can cut. If you know of a 220v one, I'd be interested to hear about it.
Lincoln has one I thought that had a built-in compressor and could also use external
air when cutting thicker material.
I think it was their Tomahawk line that came out about a year or two ago.
   / Plasma cutting - how much air do I really need? #57
I've had a hypertherm 45 for about 5 years now , no trouble I absoulutely love it. Out of all my tools it would be 1 of the last to go, my oxy , acet just sits and collects dust.i have proBley fabricated enough items to pay for it many times over. What you think you don't need may actualy be needed more than you think. I highly recommend hypertherm.
   / Plasma cutting - how much air do I really need? #58
I was in the same boat. It wasn't the amount of money but the fact that it was a large chunk of money for a tool that I would love but only occasionally use. I finally broke down and bought one from Everlast after others here had good things to say about them. Every time I use it I'm extremely happy that I bought it but it sits, sometimes months between uses. I would even love a CNC table with a plasma cutter but know that I would never use it. But if I look around my shop/ garage I can come up with dozens of tools that I don't need. For example I have a cordless, corded, and several pneumatic impact wrenches, I could easily get by with just one. But I have accepted that my wants make me happy and who can put a price on that?
   / Plasma cutting - how much air do I really need? #59
I am the same....when I bought my first cnc plasma (about 14 years ago) I told my wife that I would pay for it (working nights and weekends) in about 6 months.....I had no idea if I could, and I'm not sure she believed me...but she reluctantly agreed. I learned how to use it and ran it pretty hard on nights and weekends...and earned enough to pay it off 100% in less than 6 months. Today it is mine (PlasmaCam, Powermax85) and is used for hobby use mostly. I take on a few jobs here and there to keep my tool buying slush fund active.
I find myself using the cnc plasma for more things than I dreamed of originally. From complex cut parts, to artwork, to making a simple washer. I can walk to the PlasmaCam and draw a simple gusset, bracket, washer....in just a couple of minutes, thow the appropriate material on the table and have the part in a few more seconds. Most small welding shops in my area come to me often when they need a part quickly...as I can often cut it and sell it to them for less than they can make it themselves. When my machine is on, and I'm cutting parts for hire...it earns at least $100 per hour.
If I didn't have a great job at Hypertherm....I would be able to earn a good living with the PlasmaCam in my shop...I have no doubt whatsoever! Next to the angle grinders...the most used tool in my shop is the cnc plasma.
Jim Colt
   / Plasma cutting - how much air do I really need? #60
I have an Everlast, mine works great and saves alot of oxy accet. cost. Cuts in less time and alot cleaner cut.
As for dry air, I have copper lines in my garage with 3 "zig zag" setups with low drains to cool the air. One dryer at the end of the run and another on the machine. Never had an issue with moisture in all sorts of temps (unheated garage).
Get the right plasma (big!) and you will never go back....though it cannot take the place of the oxy for heating and such![/QUOTE]
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
KBH Water Trailer BNT-1 (A61306)
KBH Water Trailer...
UNUSED IRANCH 37" HYD MINI WOOD GRABBER (A60432)
UNUSED IRANCH 37"...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
