Plasma cutting square tubing or angle iron
   / Plasma cutting square tubing or angle iron #31
One thing I found out the hard way about the plasma is that it tends to harden the steel on either side of the kerf. It can be hardened so much that it will ruin a band saw blade when trying to cut through the heat affected zone. It’s only a few thousandths thick, but it’s enough that saw teeth don’t like it at all.
Interesting. Never knew that.
   / Plasma cutting square tubing or angle iron #34
I did a lifetime of farming (50 years) of cutting with oxy-acetylene and added an abrasive chop saw when they came out.
Now that I知 retired I have a couple of bandsaws
View attachment 568904View attachment 568905
a power hacksaw
and a plasma cutter
As someone else mentioned a chop saw (abrasive or dry cut) would probably be your best choice.
Nice restro on that Ellis :)
   / Plasma cutting square tubing or angle iron #35
Thanks, pgk!
   / Plasma cutting square tubing or angle iron #36
I believe the hardness is from formation of nitrides.
   / Plasma cutting square tubing or angle iron #37
Plasma all the way. Although very unforgiving with mistakes, once you get the hang of it, you'll wonder how life existed without. Have a 9x16 band, deep cut porta band, abrasive and angle grinders. All work in various applications. My plasma is the goto for most jobs. Cutting sheet aluminum or steel is a pure joy. I try to use a straight edge wherever I can. Saved hrs of drilling when I installed the cutting edges on my land plane. Needed quite a few 5/8 holes, a quick one hole jig, clamp in place and pop a hole. Took seconds for each hole.
   / Plasma cutting square tubing or angle iron #38
Are you talking about piercing for bolt holes? I haven't tried that yet. I suppose you blast with a jig and then drill out to final diameter? Sounds like I need to experiment with hole jigs to see what I can do!
   / Plasma cutting square tubing or angle iron #39
Yup, pierce in the middle, work to the guide and do a circle dance. I did eighteen holes in 3/8x3"x six ft angle in short order. Setting those pieces up in the drill press would be a major PIA. Trying to drill to final size would likely eat the bit, as was stated before, there is a hardened are at the cut.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
INOP/NON-RUNNING 2005 Kenworth T800 Tandem Axle Day Cab Truck, VIN # 1XKDD09X85R091127 (A54865)
INOP/NON-RUNNING...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
