Pneumatic Grease gun?
   / Pneumatic Grease gun? #61
You must not have much experience with a GOOD air powered grease gun. You can definitely tell when its pumping grease and how much your putting in. I can also hear a change in the sound of the pump when it gets low on grease long before the line stops pumping grease at the zerk.
OK, I concede, I don't know what I'm doing...
SR
   / Pneumatic Grease gun? #62
Problem with air powered guns, they SOUND like they are delivering grease, even when they aren't! I HATE that, if the grease is cold or the zerk isn't taking grease well, the gun still sounds like it's greasing fine...
SR
That's a good point to bring out, I never used one, that's one plus for hand pump grease guns I can always tell when it's not pushing out grease.
   / Pneumatic Grease gun? #63
It is a valve that replaces the drain cock on the tank.
Harbor Freight sells one that activates the drain each time the compressor cycles.
Automatic Compressor Drain Kit
Mine is electronically operated. It is set to drain for 3 seconds every 45 minutes. Weldors use such a drain when plasma cutting and needing extra dry air.
EAD General-Purpose Applications | Timer Controlled, 0 - 230 psi, unlimited cfm
eBay sells all different sorts of them.
This sounds like a good way to keep water out of the tank, think I'll get one.
   / Pneumatic Grease gun? #64
I've seen the same complaint from farmers on farm sites, most of them, like me, have abandoned the air powered grease guns LONG ago...
SR
   / Pneumatic Grease gun? #65
Maybe it's my imagination,,,,, but I am pretty sure I can tell when my rechargeable gun is pushing grease. On some applications I feather the trigger to pump slow so I can feel when the site is full.
   / Pneumatic Grease gun? #66
If you cant tell when grease is flowing or how much its one of two things a cheep gun or improper use! This holds true for many of the farmers I have met who even after years of owning them cant get them to work properly as well as the parts changers in the garage that prefer to get the manual gun out rather than use the main grease line hanging in the shop.
   / Pneumatic Grease gun? #67
I haven't used a full tube yet on my Dewalt 20v grease gun, I'm assuming I'll know when it's out of grease, if not, a guy at work told me if I had a smart phone, I could download an APP that would send me a text letting me know that I'm out of grease.
I cant feel a thing on any of my FEL grease applications, all I know is the gun is variable speed, I just keep my trigger finger on the trigger until I see grease come out somewhere.
   / Pneumatic Grease gun? #68
WOW, there's an app that texts you when you're out? I haven't really had a problem with running dry and not noticing on my Dewalt. On a lesser tech note, you could purchase an extra tube.
   / Pneumatic Grease gun? #69
On my two Milwaukee M12 grease guns you can hear and feel the subtle change when a new tube of grease is required. Changeovers are fairly simple, never a problem. Greasing equipment is much less of a chore! The low on grease app from Milwaukee is currently only available on iOS.
   / Pneumatic Grease gun? #70
Does it have a wireless connection or something to detect the "out status"?
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
Galvanized Steel Fence 10ft x 7ft (A55758)
Galvanized Steel...
2016 Chevrolet Caprice Sedan (A55758)
2016 Chevrolet...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
