Pneumatic Grease gun?
   / Pneumatic Grease gun? #51
Ah...but there's an idea for everything it seems. https://www.youtube.com/watch?v=_E1yP5NV9NY
As I mentioned, I did that with my 18v Ryobi batteries.
I used one of the old blue Ryobi flashlights. With a little sanding, to make the parts fit precisely one inside the other, it looks like I never did anything to it.
Had a lot of fun with my boss. I convinced him for a while, that Ryobi 18v batteries actually fit on his Lincoln grease gun. :D
   / Pneumatic Grease gun? #53
My shop is air plumbed. The compressor is in the rear of the shop inside the bathroom so it's inconvenient to shut off the valve. So I wired the compressor to only have electrical power when the shop lights are on. Shutting the lights off as you leave the shop shuts the compressor off, so if there's a break when I'm not there it'll just drain the tank and not burn the compressor up trying to maintain pressure. :)
My upright air compressor is upright up stairs, so mine is more inconvenient to shut the valve off, it's hard wired to the breaker panel down stairs, so when I'm done throwing hammers, I just shut the breaker off. I told my son the new rule is, the breaker panel door stays open when air breaker is on, breaker panel door is shut when breaker is off, that should stop the 2:00 am air compressor wake up call.
   / Pneumatic Grease gun? #54
Problem with air powered guns, they SOUND like they are delivering grease, even when they aren't! I HATE that, if the grease is cold or the zerk isn't taking grease well, the gun still sounds like it's greasing fine...
SR
   / Pneumatic Grease gun? #55
Three words, what's auto drain?
It is a valve that replaces the drain cock on the tank.
Harbor Freight sells one that activates the drain each time the compressor cycles.
Automatic Compressor Drain Kit
Mine is electronically operated. It is set to drain for 3 seconds every 45 minutes. Weldors use such a drain when plasma cutting and needing extra dry air.
EAD General-Purpose Applications | Timer Controlled, 0 - 230 psi, unlimited cfm
eBay sells all different sorts of them.
   / Pneumatic Grease gun? #56
SR
When my Lincoln runs out of grease it pumps much faster. If the Zerk is plugged then it pumps very slowly. Plugging is not so much of a problem with high air pressures.
   / Pneumatic Grease gun? #57
That was my original plan. But the wholesaler I bought all my electrical from said "why don't you use a relay?" I had actually never thought about it. So now I don't have to worry about whether my breaker box door is open or shut..... :)
P.S. Cost me $50.
   / Pneumatic Grease gun? #58
As gwdixon said. Of course I'm such a procrastinator that I bought mine two years ago and still haven't installed it yet.
   / Pneumatic Grease gun? #59
BUT, you still don't know how much grease is going in....especially if the grease is cold...
SR
   / Pneumatic Grease gun? #60
SR
You must not have much experience with a GOOD air powered grease gun. You can definitely tell when its pumping grease and how much your putting in. I can also hear a change in the sound of the pump when it gets low on grease long before the line stops pumping grease at the zerk.
Kubota M108S (A53317)
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A60460)
2012 Vermeer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
