pole barn make use of cut tree's
   / pole barn make use of cut tree's
Re: pole barn make use of cut tree\'s
Did I fail to mention the rock would be about 2' by 2' by 4'?
Ok, I ment a boulder. /forums/images/graemlins/smile.gif That, in the ground, under the posts would certainly hold. A contractor I talked to said to set the post then drill through both and drive the spike into the rock.
   / pole barn make use of cut tree's #22
</font><font color="blue" class="small">( Most of the time they are stripped by a homemade debarker or often a special cuttin edge we mount onto a boxblade to power peel the logs before curing. )</font>
Hhhmmm...
Tell us about the tools. (Pictures please...)
   / pole barn make use of cut tree's #23
Here is pic of my partialy finished pole barn built mostly from sawmill lumber, one of my friends built his this way about 10 years ago and it is still doing fine. Dont laught im no carpenter. /forums/images/graemlins/crazy.gif
   / pole barn make use of cut tree's #24
here is is from behind still have alot of work to do on the property too.
   / pole barn make use of cut tree's #25
from this far up the holler or hollow however you want to say it, you can see the red roof. I started to put shingles on it but after some debate i went with tin.
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
1983 Case 580D (A47477)
1983 Case 580D...
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
