pole barn make use of cut tree's
   / pole barn make use of cut tree's
Re: pole barn make use of cut tree\'s
Did I fail to mention the rock would be about 2' by 2' by 4'?
Ok, I ment a boulder. /forums/images/graemlins/smile.gif That, in the ground, under the posts would certainly hold. A contractor I talked to said to set the post then drill through both and drive the spike into the rock.
   / pole barn make use of cut tree's #22
</font><font color="blue" class="small">( Most of the time they are stripped by a homemade debarker or often a special cuttin edge we mount onto a boxblade to power peel the logs before curing. )</font>
Hhhmmm...
Tell us about the tools. (Pictures please...)
   / pole barn make use of cut tree's #23
Here is pic of my partialy finished pole barn built mostly from sawmill lumber, one of my friends built his this way about 10 years ago and it is still doing fine. Dont laught im no carpenter. /forums/images/graemlins/crazy.gif
   / pole barn make use of cut tree's #24
here is is from behind still have alot of work to do on the property too.
   / pole barn make use of cut tree's #25
from this far up the holler or hollow however you want to say it, you can see the red roof. I started to put shingles on it but after some debate i went with tin.
2014 Ford Escape (A50323)
2014 Ford Escape...
1981 LUFKIN FLATBED WINCH TRAILER (A53843)
1981 LUFKIN...
72'' power rake (A53421)
72'' power rake...
1267 (A50490)
1267 (A50490)
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
2011 MACK CHU (PINNACLE) (A53843)
2011 MACK CHU...
